IP Telephony and Phones
Labels
Hi allI'm facing an issue with CUCM 5.1 on MCS 7835 H2 server(with two 72 GB SCSI). The hard disk utilization is 91% for both the active and inactive partitions. Please advise me on how to free some diskspace or how to upgrade the HDD if required.
vdominic by Cisco Employee
  • 639 Views
  • 3 replies
Hi all I am trying to setup TAPS on my IPCC express 4.5 server.I could not find the taps.aef script.Can anybody give me the quick steps to use external IPCC 4.5 for CM 5.1. Thanks in adv.This is the link I followedhttp://www.cisco.com/univercd/cc/td...
joel by Level 1
  • 790 Views
  • 4 replies
Hello,I have IP PBX, NAT router (cisco) and SIP-phone connected as follows:IP PBX<-internet->NAT router<-LAN->SIP phoneThe problem: When I make a call from SIP phone to IP PBX the connecting goes correctly. But when I call from IP PBX to SIP phone th...
jouk by Level 1
  • 649 Views
  • 1 replies
Hi,Got an issue with a line that the Telco says is ok. Got three trunk lines going into the FXO card. One line constantly holds the FXO port off hook. It may occasionally remain on hook if it is disconnected but after the first call it remains off ho...
bigcappa1 by Level 4
  • 1810 Views
  • 9 replies
I have a customer on CME 4.x who is having issues with their received call listing. Whenever a call comes in and is transferred to another user, the received call shows up as the calling number of the transferring party, instead of the external call...
slongewa by Level 1
  • 710 Views
  • 3 replies
Hi Experts,I have a couple of router's in which I install B-ACD. IOS: (C2801-ADVENTERPRISEK9-M), Version 12.4(22)TTelephony-service CONFIG (Version=7.0(1))In one router B-ACD works, in the other one the next message is diplay:*Apr 2 15:58:04.840: //...
abrenes26 by Level 1
  • 575 Views
  • 2 replies
My customer is using UCM 7.1.2 and 2 3845 vgws (1 has local PRI and 2nd gw has LD PRI). Telco won't pass toll-free calls thru LD PRI and customer is using standard route group which is utilizing the 2nd gateway (LD) first then the 1st gw (Local). I c...
mpower78 by Level 1
  • 357 Views
  • 1 replies
