12-10-2012 07:50 AM - edited 03-16-2019 02:38 PM
I have a SIP trunk to an IVR. I would like to be able to, if all the IVR channels are full or if the IVR down to have the calls reroute to a hunt pilot. I know I could easily reroute it external to a different trunk using route groups and route list but I cant think of a way to rereoute it internal to a hunt pilot. Any help is appreciated.
Solved! Go to Solution.
12-10-2012 11:55 AM
Gene,
I've never tried this before and I'm away from my desk today so I can't test it in the lab, but you could try adding a SIP trunk to Callmanager itself and prefix a few digits in the Route Group configuration so that when the call comes back into CUCM, it can hit a hunt pilot.
Brian
12-10-2012 11:55 AM
Gene,
Brian
12-11-2012 07:10 AM
I had sort of wondered if that may work just never heard of building a sip trunk to yourself. I will give it a shot and post back with the results. Thanks
12-11-2012 01:00 PM
This did actually work. I had to build a sip trunk for the pub ip and sub ip and them in route groups and add the route groups to the IVR RL. Then just manipulate the digits. Not sure TAC would support it but it works. Thanks
12-11-2012 01:34 PM
Good to hear! I actually work in TAC and wouldn't give you too much hassle with this. I wish I had a better solution for you, but once CUCM locks onto a Route List, it isn't going to try anything else other than other members of the Route List. I have a few other ideas, but they would be even worse it terms of completely unsupported by TAC
