(resolved) Call Forward and No Answer Ring Duration issue (cucm 11.5)
gdossantos1
Hi everyone,
I am having issues configuring Call Forwards.
Meaning : what I expect is since I don't have currently voice mail enabled, when an external call arrive on say phone 1. I want that the call be forwarded to phone 2 after 5-6 rings (default is about 3 rings which is not enough in my case).
So in the phone 1 configuration I put Forward No Answer External to Destination Phone 2 which works well.
Then I changed the default for "Forward No Answer Time" in order to have my value (24 secs) for all phones instead of just editing the "No Answer Ring Duration" of phone 1 and all phones.
When I received an external call on phone 1, it rings 5-6 times (24 secs) like expected but then it is forwarded to phone 2 that instantly drops the call.
If I keep the configuration for the forwarding but put defaults settings for the "Forward No Answer Time"(12 secs) , phone 1 rings 3 times (12 secs) then phone 2 rings 3 times too. All is working as expected.
So my thinking was that there is somewhere a timeout that drops the call when it reaches 24 seconds. But I've searched in all the settings and Cisco docs and I don't find anything like that. I mean there are values that must be greater that Forward No Answer Time but they all do are greater already even when I put 24 seconds.
Even if my phone 2 is actually a Hunt Pilot, I still have the same issue.
Can somebody tell me what I should check to resolve this issue?
Many thanks in advance
2 Accepted Solutions
Couple of options:
1. Collect debugs at the gateway to determine the disconnect cause.
2. Contact the carrier to see what they see on their end when the call is disconnected.
Brandon
gdossantos1
Hello everyone,
I resolved this. It was in fact a setting to change in my GUI from my SIPtrunk provider.
By default, it was set to drop calls after 25 seconds.
12 Replies 12
Brandon Buffin
What is the setting for the T301 timer (in Service Parameters)? Default is 180000 msec. It should be greater than the Forward No Answer Timer.
Brandon
Brandon,
It is one of the values I was talking about that are already greater than 24 seconds. (As for this one in particular I let the default setting)
When set to 24 sec, does phone 2 ever ring? Could your carrier have a ring no answer configuration on the line?
Yep, phone 2 does ring but just for like 1 ms then it drops the call.
But when it is set to 12 seconds, phone 2 does ring just fine.
I don't think my carrier have a ring no answer conf because I previsouly had an issue with which an unanswered call was ringing for ever even though the caller had hang out.
Don't ask me how I resolve this issue in particularI didn't, it was the guy that set up the system that did and I don't know how (I can ask though)
If you set the internal Forward No Answer destination and call the phone internally does the same thing happen?
No, in internal it's all good.
Couple of options:
Brandon
Hi Brandon,
Sorry for the delay.
Thanks for your help !
gdossantos1
Hello everyone,
Hello Santos, Where is this option exactly? are you taking about SIP expire or connect timer under service parameter > Call Manager ?
Hi Anthony,
I wasn't talking about some parameter in CUCM.
The timeout was a setting from my SIP Trunk provider (OVH Telecom).
It was indeed a SIP expire at 25 seconds
Oh ok, thanks for your information :)
