05-09-2016 05:38 AM - edited 03-18-2019 11:59 AM
We are receiving external calls from 000000 and i want to hide 000000 and show display.
I setup a TP with pattern 000000 but i cant hide the 000000. I know that cucm is using that TP because i can block/route the call.
i can put 1234 as Calling Party Transform Mask and i will see 1234 but cant find a way to make it "unknown"
any idea?
thanks
05-09-2016 06:05 AM
Louis,
Try and change the TP "
Calling Line ID Presentation" to restricted
05-09-2016 06:11 AM
Hi Ayodeji,
it's already set to restricted. thanks
05-09-2016 08:46 AM
One way of doing it is which i have tested is...
On SIP Trunk inbound CSS - match a Translation pattern for called number and then restrict the Calling line id presentation before sending the call to the actual DN.Thanks
05-09-2016 10:57 AM
hi
it can be any called number.... i need to do it on the calling TP. see my diagram, if cli = restricted etc... it will display 000000, i need to change that to restricted. my user DN are in eu_internal partition.
thanks
05-09-2016 11:59 AM
Thanks ,it is clear now what you are trying to achieve .Just trying to think loud here.
Can you try restricting it on SIP trunk level and reset the trunk , i know this is not what you are looking for however this will give us an idea if calling restriction works or not in this set up.
Or instead of unknown you can try * or + any other supported character.
05-10-2016 12:10 AM
hi
i restricted it on the trunk and reset but still the same.
i put a + and it displays plus
it used to work
thanks
05-10-2016 01:58 AM
So what does the display on the phone show when you set calling line ID to restricted?
05-10-2016 02:12 AM
shows the caller cli
05-10-2016 04:10 AM
We will need to look at CUCM logs to see what is going on. I just tested this now on my translation pattern from a call that came in via a sip trunk and it showed "private" Can you send us CUCM logs..
05-10-2016 05:01 AM
05-12-2016 01:58 AM
What is the detail for the call. Calling number, called number, time of call etc
05-12-2016 02:18 AM
oops sorry
calling: 000000
called: +3222249810
Time: 12:56 UK
Date: 10May
thanks
05-12-2016 04:00 AM
It appears like the log you provided you have used + as the calling party mask..
Here is what I see in the logs for 12:56..
97527335.008 |12:56:44.425 |AppInfo |Digit analysis: analysis results
97527335.009 |12:56:44.425 |AppInfo ||PretransformCallingPartyNumber=+
|DialingPartition=EU_Internal
|DialingPattern=+3222249810
97527376.003 |12:56:44.427 |AppInfo |StationCdpc: CcSetupReq - unicodeCallingPartyName='' asciiCallingPartyName='Unavailable' callingParty='+'
I expect in this case that a + is displayed on the phone..
I also see that you are doing restriction on the called number. I can see privacy on the called number..
SIP/2.0 180 Ringing
Via: SIP/2.0/TCP 10.20.4.156:5060;branch=z9hG4bK06Bf1831c41dcd1ea14
From: "Unavailable" <sip:000000@va.sip.colt.net>;tag=gK06208635
To: <sip:+3222249810@10.20.44.21>;tag=76405267~691d352a-3cdb-4674-beac-9a44bf063354-147891208
Date: Tue, 10 May 2016 11:56:44 GMT
Call-ID: 1275506742_12098250@10.20.4.156
CSeq: 11651 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Server: Cisco-CUCM10.5
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Brussel Test" <sip:+3222249810@10.20.44.21>
Privacy: id
Remote-Party-ID: "Brussel Test" <sip:+3222249810@10.20.44.21>;party=called;screen=yes;privacy=full
Contact: <sip:+3222249810@10.20.44.21:5060;transport=tcp>
Content-Length: 0
I need a log for when you only did caller id rectriction without any mask..
Please note that the logs should be taken only from the ff server..
gbsloccmlp0002.qbe.eo
05-12-2016 04:10 AM
