Retrieve CDR data from backup
Sakun Sharma
I want to some old CDR data information from CUCM. I have old backups with CDR_CAR.tar file, but I am unable to open them. Is there a way to open those file and get the CDR dumps?
Sakun
6 Replies 6
Aeby Vinod
Level 3
Level 3
Try the DRS Backup Decrypter tool a shot, haven't done it personally but read it can be effective in previous threads.
https://www.adhdtech.com/uctools.html
If not you can build a CUCM node with same hostname/IP/security password etc as the original node and restore the backup there to retrieve the records.
Please rate if you find this helpful.
Aeby
Aeby
Its unable to read my 9.1.2 XML file - error in the file, but it was able to read 8.6 XML file successfully. I am still trying, hopefully, it works.
Thanks for sharing this.
Did you find any solution?
Rajan
Hi Sakun,
have you tried unzipping the tar file using winzip or 7zip ?
Rajan
Pls rate all useful posts
Yes, it gives me error message corrupted. I guess its encrypted.
Hi Sakun,
Are you able to extract i have done the all type of tool to extract but no luck!!!!!!!!!
