04-22-2013 10:37 PM - edited 03-16-2019 04:57 PM
Hi to all,
I'm installing a new CUCM with DNS information configured but I'm getting an error message about Reverse DNS lookup.
I have a register in the dns for the name of the cucm and reverse dns lookup for the network that this server has configured.
Does anyone knows what exactly has to be configured in the DNS server in order to support the dns configuration for the cucm???
Here I attached the error message.
Please your help.
Thanks in advance.
Solved! Go to Solution.
04-23-2013 01:42 AM
Hi Alfonso,
Please check whether DNS server is reachable from Call Manager by using utils network ping command .
Secondly, seeing the error message it looks that Reverse DNS lookup needs to be configured on Windows 2008 Server on which u have installled DNS functionality.
Please refer this for reverse DNSlookup configurration.
http://technet.microsoft.com/en-us/library/cc725670(v=ws.10).aspx
Also, are u using any underscors in Publisher and Secondary Hostname which seems to be limitation on Microsift DNS servers.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b26146.shtml
regds,
aman
04-23-2013 06:54 AM
Yes, you also need the PTR.
Create it manually and reload the zone.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
04-22-2013 10:38 PM
The DNS server is a Win2k8
04-23-2013 01:42 AM
Hi Alfonso,
regds,
aman
04-23-2013 05:39 AM
Hi Aman,
Thanks alot for your reply, I have configured all that but is still not working...do you know if I have to check the option "Create Associated Pointer (PTR) Record" when I create the dns record in the dns server??
Thanks in advance
04-23-2013 06:54 AM
java
04-23-2013 08:00 AM
Hi Alfonso,
Thanks to Mr. Jaime.
Please refer the URL for adding PTR.
http://technet.microsoft.com/en-us/library/cc844045(v=ws.10).aspx
Please share findings on Call Manager installation the point where it is getting stuck.
regds,
aman
03-11-2018 10:35 PM
Keep getting Reverse DNS lookup mismatch, however I re-created the zone several times and only one PRT on server, how is reverse dns not working?
