05-18-2015 06:06 AM - edited 03-17-2019 03:02 AM
Hi all,
I would like to know how I can restrict users from
Thanks.
05-18-2015 06:13 AM
CUCM or CME?
05-18-2015 06:14 AM
Hello.
Sorry CUCM
05-18-2015 06:19 AM
OK
Select a phone and go to the bottom part "Product Specific Configuration Layout" Here is an option "Settings Access" and select what you want, restart the phone and test
Bye
JH
05-18-2015 06:33 AM
Hello JH
I
05-18-2015 06:48 AM
It's at the bottom of the page.... did you search for "Settings Access"? What type of phone is this?
05-18-2015 06:56 AM
setting access is enable and the phone type is Cisco 9971, but when I go to the phone options, I have the message "cant get additional tones from the server"
05-18-2015 07:27 AM
What are you trying to do? Your original post said you wanted to restrict ring tone access which requires you to disable the settings access on the CUCM page. Is there a problem with restricting access or actually selecting a ringtone?
05-18-2015 10:01 AM
I have some user that needs to be restricted to change ringtones and some not.
05-18-2015 10:32 AM
Ok, then both mine and huizinga's advice applies. Go into the CUCM and disable settings access for the phone in question.
05-18-2015 12:13 PM
05-18-2015 06:18 AM
Device --> Phone --> "Your phone" --> Settings Access = "Disabled"
05-18-2015 02:44 PM
follow the below steps
kindly check as Correct answer if it Support you
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/9_0/english/user_guide/P746_BK_I8055398_00_ip-phone-7941g-7941gge-7942-7961g-7961gge-7962-userguide/P746_BK_I8055398_00_ip-phone-7941g-7941gge-7942-7961g-7961gge-7962-userguide_chapter_0101.html#P746_TK_C635A2CC_00
to access the phone after step one press **#
to unlock the settings !
