06-16-2016 09:35 AM - edited 03-17-2019 07:16 AM
Hello all,
I need know how configure and limit ringing duration ip phone in cucm .
Can you help me please
Thank you
06-16-2016 09:47 AM
On line/directory page of phone (cucm admin page -> device -> phone ) there is an option "ring no answer" field , you can set there timer in seconds, and you can set call forwarding to voicemail in Ring no answer case so as soon as that timer expires phone will stop ringing and call will go to voice mail.
Suresh
06-16-2016 10:06 AM
Hi suresh hudda
Thanks for your answer
if I want to stop the alarm without going to voicemail.
is that there's a method to apply to all the IP phones.
Thank you
06-16-2016 10:12 AM
There is is a service parameter "forward no answer timer" you can set it appropriately.
For more info see below link..
https://supportforums.cisco.com/discussion/11467836/change-time-no-answer-ring-duration-cucm
Suresh
06-16-2016 10:20 AM
Thank you for your help
Best regards
06-16-2016 10:24 AM
With this, I am assuming that you want to stop the ringing on the phone without going to VM. If this is correct, then create a dummy DN and do a call forward on that for the Forward No Answer parameter and call will go to this number and disconnect/busyOut then.
Deepak
