06-13-2009 08:57 AM - edited 03-15-2019 06:31 PM
Hi Gurus,
Is there any method yet to route outgoing calls based on calling number on a gateway apart from blocking incoming calls based on the calling number?
Shad
06-13-2009 09:32 AM
Yes, see:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
Now tell me that you want to use your new freind trunk-groups for that ?
06-16-2009 03:10 AM
you could also use answer address on your inbound voip dial-peer and translate the matched number to whatever you want then the translated numr will match a pots dial-peer
06-16-2009 04:07 AM
That is exactly what the document linked above explains in detail.
06-18-2009 02:55 AM
Hi guys,
Thanks for replying. It worked for me.
Paolo, I am still not able to get over the incredible feeling of the new friend pri-group. So I will not answer that question yet. Maybe later sometime. Let me enjoy the moment. ;)
Shad
