Route List Issue
ahmad_tamneh
Level 4
Level 4
Hi all,
I have MGCP GW, registered with CUCM 8.5, the gatway has 3 fxo they are grouped with one Route Group, this route group is member of route list, when I try to make a call from this route list, the call always go through one fxo port 0/2/2, and never go with the other ports.
debug MGCP errors  :
Jun 26 10:48:11.213: //-1/9EB9F8918041/MGCP|aaln/S0/SU2/2|-1|-1/<VOICE>/mgcp_trans_kpstseq_to_anidnis(218):[lvl=0]Going to traverse the Sig event list
Jun 26 10:48:15.849: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]Invalid parameter (pkt 0x48045390 pkt->mgcp_parm_lines 0x00000000)
Jun 26 10:48:15.853: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]Invalid parameter (pkt 0x48045390 pkt->mgcp_parm_lines 0x00000000)
Jun 26 10:48:15.857: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]Invalid parameter (pkt 0x48045390 pkt->mgcp_parm_lines 0x00000000)
Jun 26 10:48:43.946: //-1/xxxxxxxxxxxx/MGCP|aaln/S0/SU2/2|-1|-1/mgcp_allocate_if(8232):[lvl=2]ccAllocateIF failed rc -6 vdbptr 0x47AE8A94 alloc_vdbptr 0x0
Jun 26 10:48:43.946: Following traceback is for INFO ONLY. -Traceback= 0x40CDF690 0x40D08070 0x40CAEE4C 0x40CE129C 0x40CE0C30 0x40C9F454 0x40C9F654 0x40CA0334 0x40CA09A8 0x40CA0CA0 0x40CA0E88 0x40CA2894
Jun 26 10:48:44.962: //-1/xxxxxxxxxxxx/MGCP|aaln/S0/SU2/2|-1|-1/mgcp_allocate_if(8232):[lvl=2]ccAllocateIF failed rc -6 vdbptr 0x47AE8A94 alloc_vdbptr 0x0
Jun 26 10:48:44.966: Following traceback is for INFO ONLY. -Traceback= 0x40CDF690 0x40D08070 0x40CAEE4C 0x40CE129C 0x40CE0C30 0x40C9F454 0x40C9F654 0x40CA0334 0x40CA09A8 0x40CA0CA0 0x40CA0E88 0x40CA2894
I also see this error
Error on Voice Gateway FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally
the show voice dsp group all slot 0 :
Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 0
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 4
    Voice channels allocated: 0
    Credits used: 0
Another thing worth to mention is that: When I put each  individual fxo in an individual rout group I can make 2 calls simultaneity
the sh run, sh diag, sh version is attached
any Idea?
Thnaks
Ahmad
Ahmad,
Is it the same symptoms if you activate the SRST ? i mean if you disconnect the link and the branch became on the SRST mode , how many calls can you make ?
Amer
Hi Amer,
Let me check to answe you.
Ahmad
