Route Pattern query
singh-ashok
I am trying to configure a Route Pattern for the range 72425 - 72524... I configured 72[45]XX. Is there a better / shorter way to do this ?
5 Replies 5
phooghen
I don't think there is a shorter way to do this.
There is probably a better way to limit the range by creating multiple Route Patterns but I don't think this is what you are looking for.
Pierre.
Pierre,
Yes you are right. I was just trying to find out if I had a way to consolidate this range into one RP & avoid configuring multiple ones.
Best Regards,
Ashok.
JATINDER KUMAR
i doubt u r correct on 4th digit...
becoz it can take values less then 25 also.. please see if u want that
Jatin
Jatinder,
You are right. I had this doubt too. That's why looking for expert opinion.
You cannot configure that in just 1 statement, you need at least 4 patterns to cover that range, your lower and upper limits cause a lot of problems when it comes to summarizing.
You need to cover this 4 ranges each with 1 route pattern.
72425-72429
72430-72499
72500-72520
72521-72524
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
