Route Patterns for Taiwan and China in CUCM?
Tommer Catlin
Anyone know the "rules" for Taiwan and China for CUCM?
<br />
<br />I found some notes, but does not make sense on how to program the RPs:
<br />
<br />Local format is 9-xxx. xxxx ( 7 or 8 digits ) (Taiwan)
<br />Long distance format is 9-0x ( area code)- xxx. xxxx (Taiwan)
<br />International format is 9-002-country code xxx....xxx (Taiwain)
<br />
<br />China:
<br />Long distance format is 9-0x..x ( area code )- xxx. xxxx (Area code varies though?)
<br />
<br />International format is 9-00-country code xxx.....xxx
<br />
<br />Anyone have some guidelines?
<br />
<br />Cheers!
<br />
Did you ever get this resolved?  I am trying to build out route patterns for a clients device pool in Shanghai and its crazy confusing on how their dialing formats are structured.  Please let me know if you have any input?
Thank you,
MAC
For China check out the link below:
http://www.cisco.com/web/software/282074292/48520/CNNP.txt
It is the flat file contents of Cisco's China dailplan for CUCM.
Appreciate you James, this helps tremendously.
MAC
