Router 2801 without IOS and CME
Hi, I buy on Ebay cisco router 2801 without IOS, oke, I will find IOS and copy on router, problem is CME, I want to start learning for CCNA Voice, I have 2 phones, 7940 and 7912, How can I install CME on Router and, where to find for me (not bissnis) CME, and what verision to use for CCNA Voice ?
CCNA R&S, CCNA Security
ronpatel
Level 8
Level 8
HI
CME comes with the IOS only. SO when you install the Cisco IOS, the CME componenet is installed automatically.
You just need to enable those commands and it will work. You have to use Voice Images to get this feature.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
HI
Ronak Patel
Rate helpful posts.
