router 2811 with two PVDM, (PVDM2-16 'n' 2-32), but voice-card 0 showing
rammany19
hello
i have two pcs of PVDM2 in cisco router 2811, but its only voice-card 0 showing, how can i configure the second one which suppose to be voice-card 1?
They should already be pooled.
(basic voice card config)
voice-card 0
no dspfarm
dsp services dspfarm
then for example if you are doing transcoding
dspfarm profile 2 transcode
maximum sessions ?
the "?" will indicate how many DSP resources are available (this will be half as 2 DSP's are required for each complex transcoding session)  But it will give you an indicator that you are seeing all you resources.
Cheers
Dave
dkemp
rammany19,
     The "voice-card 0" is the 2 PVDM slots on the motherboard (both PVDM slots).  Voice slot 1 would appear when you add a voice NM into slot 1.
Cheers
Dave
How do i share resources with 2pcs of PVDM, is it with their serial number using "show inventory" command?
voice-card 0
no dspfarm
maximum sessions ?
Cheers
Dave
