08-28-2011 03:54 PM - edited 03-16-2019 06:43 AM
hello
i have two pcs of PVDM2 in cisco router 2811, but its only voice-card 0 showing, how can i configure the second one which suppose to be voice-card 1?
Solved! Go to Solution.
08-28-2011 04:40 PM
They should already be pooled.
(basic voice card config)
voice-card 0
no dspfarm
dsp services dspfarm
then for example if you are doing transcoding
dspfarm profile 2 transcode
maximum sessions ?
the "?" will indicate how many DSP resources are available (this will be half as 2 DSP's are required for each complex transcoding session) But it will give you an indicator that you are seeing all you resources.
Cheers
Dave
08-28-2011 04:29 PM
rammany19,
The "voice-card 0" is the 2 PVDM slots on the motherboard (both PVDM slots). Voice slot 1 would appear when you add a voice NM into slot 1.
Cheers
Dave
08-28-2011 04:34 PM
How do i share resources with 2pcs of PVDM, is it with their serial number using "show inventory" command?
08-28-2011 04:40 PM
voice-card 0
no dspfarm
maximum sessions ?
Cheers
Dave
