09-06-2015 09:57 PM - edited 03-17-2019 04:14 AM
Dears,
I have one customer having 500 branches and they are using 2921 with CUE module, they decided to change the router by 4331 with ucs-e module.
My question how this solution will work (configuration, installation, design).
Thanks in advance.
Ali
Solved! Go to Solution.
09-06-2015 11:30 PM
Hi Ali,
You can go for Unity Connection installation on 4331 ISR but the number of users is limited to 150 on BE6000 Small.
regds,
aman
09-06-2015 11:30 PM
Hi Ali,
regds,
aman
09-06-2015 11:39 PM
Dear Aman,
Thanks for your email, what i need to know, how this scenario will work is that need to have a main unity connection in the data center and UCS-E as branch unity connection how to connect each other also is that need to have licenses in both unity. i search a lot for that but i cannot find a clear documents.
Ali
09-07-2015 03:00 AM
Hi Ali,
this is what I could find but I doubt this is going to help .
regds,
aman
09-07-2015 06:46 PM
You will just install the VMWare hypervisor and then UC apps on top of the ESXi host as per any other UCS server. The document my friend Aman has provided should have the details how to connect and setup the UCS blade on router.
I noticed you have given his post a very low rating - I will rate Aman's post (+5) but I would encourage you to use the rating generously for some one taking the initiative of helping you.
Now regards to the application design, A Unity Connection cluster can only have two servers in the cluster. If your DC already has a CUC installed as the publisher you can install the CUC on UCS-E as sub server (with first node as your DC server). Refer to the design guide for cluster overview and network requirements, if you go through this you should be able to get all the information you need:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx/10xcucdg060.html#pgfId-1050709
But in case you already have a Unity Connection cluster and want to connect two clusters, refer to below section of the design guide:
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx/10xcucdg030.html#pgfId-1057296
I would recommend to read through the design guide for a solid understanding. Please let us know if you have got any more queries.
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries.
09-07-2015 08:23 PM
[+5] to Terry for adding more value.
regds,
aman
