placed call being ansewred or NOT ??
saif musa
Level 4
Level 4
Hello community,
How could I identify if my placed call on FXO port is being answered by the called party or NOT, using debug command. Im using cisco router 1700 series with VIC2-2FXO card.
Thanks in advanced
Connected means that call is established and media stream already started
5 Replies 5
Manish Gogna
Hi Saif,
You can analyse a call using "debug voice ccapi inout" as explained here
http://www.cisco.com/c/en/us/support/docs/voice/h323/14081-voip-debugcalls.html#voipccapi
Manish
- Do rate helpful posts -
Manish,
Thanks for your reply.
after the two gateways changes capabilities ( codec, vad, voip or fax ... etc ), and there will be an agreement from both sides. the call is connected. now ( connected ) means that the called part is ringing ( the calling party can hear ring tone, busy tone etc..)  OR the call has been answered by the called party ?
Thanks, thats correct
Thanks, the document solves my inquiries
