Router can see Pub, but not Sub when show ccm-manager
wfqk
Level 5
Level 5
Hi. We have two call-managers: Pub and Sub. The router can ping both' ip address. and both Pub and Sub are activated already. When showing ccm-manager in the router, we can see Pub ip address, but cannot see Sub ip address. Anyone can give some suggestion? Thank you
2 Accepted Solutions
Your MGCP config looks to be incomplete / incorrect as the gateway doe snot show registered in the output.
Also, you need to add ccm-manager redundant-host {ip-address of Sub } in the config of gateway.
Make sure that the gateway is added with domain name R1.ccievoice.com on cucm page. Once you make any changes, reset the gateway from cucm page.
Manish
- Do rate helpful posts -
Just found something in the config, you have configured port 0/1/0 on gateway for isdn bind-l3 ccm-manager
interface Serial0/1/0:23
no ip address encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
However you have configured port 0/0/0 on cucm page, make sure they are the same on cucm page and gateway.
Manish
20 Replies 20
Chris Deren
Please provide your configuration and output of the show ccm-manager.  Did you configure both in your MGCP configuration?
Thank you for your reply.
Do you mean both in router or cucm?
Please see the below, especially highlighted by bold
R1(config)#do sh ccm
MGCP Domain Name: R1.ccievoice.com
Priority Status Host
Primary Registering with CM 192.100.64.11
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 20:17:57 UTC Dec 21 2015 (elapsed time: 07:29:20)
Last MGCP traffic time: 03:46:50 UTC Dec 22 2015 (elapsed time: 00:00:27)
Last failover time: None
Last switchback time: None
Switchback mode: Immediate
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 192.100.64.11
Current Link State: OPEN
Statistics:
Packets recvd: 0
Recv failures: 0
Packets xmitted: 0
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 1, port 0
Configuration Auto-Download Information
Current version-id: 1450573173-d9e2d175-c55-4652-9336-0312e3e9
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 3
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
R1(config)#
Manish
Thank you for your reply. You are right. After adding the command, I can see sub. And
why did you say "the gateway doe snot show registered in the output."
Thank you
Manish mentioned that because in the below output, it shoud show as registered instead of registering.
So as suggested by Manish, you need to make sure that you have added teh gateway as "R1.ccievoice.com" in CUCM and also check the DP is correct.
Yes, Thank you all
I just noticed the status of pub and sub are changing. Do you think this is normal ?
First Backup Backup Ready 192.100.64.12
Second Backup None
R1#sh ccm-manager
Primary Backup Ready 192.100.64.11
First Backup Registering with CM 192.100.64.12
Second Backup None
Can you share screenshots of the gateway config page on cucm and the latest show run.
Manish
Please see attachment.
The config looks good, Can you reset the MGCP gateway from cucm page and the do a no mgcp / mgcp on the gateway. If the endpoints still show registering on gateway then check if router is able to ping cucm and vice versa. Get the "debug mgcp packets" from gateway after resetting it from cucm page.
Manish
I did all based on what you said except ping from cucm to the R1 as I did not find where to put the ping command. Show ccm is still the same as before. The below is debug output
R1#debug mgcp packets
Media Gateway Control Protocol packets debugging for all endpoints is on
R1#
Dec 22 05:08:11.248: MGCP Packet sent to 192.100.64.11:2427--->
RSIP 252530318 *@R1.ccievoice.com MGCP 0.1
RM: graceful
Dec 22 05:08:11.248: MGCP Packet sent to 192.100.64.12:2427--->
RSIP 252530320 *@R1.ccievoice.com MGCP 0.1
RM: restart
Dec 22 05:08:11.252: MGCP Packet received from 192.100.64.11:2427--->
200 252530318
Dec 22 05:08:11.252: MGCP Packet received from 192.100.64.12:2427--->
500 252530320
R1#
R1#
R1#
Dec 22 05:08:41.245: MGCP Packet sent to 192.100.64.12:2427--->
RSIP 252530322 *@R1.ccievoice.com MGCP 0.1
RM: forced
Dec 22 05:08:41.249: MGCP Packet sent to 192.100.64.11:2427--->
RSIP 252530324 *@R1.ccievoice.com MGCP 0.1
RM: restart
Dec 22 05:08:41.253: MGCP Packet received from 192.100.64.12:2427--->
200 252530322
Dec 22 05:08:41.253: MGCP Packet received from 192.100.64.11:2427--->
500 252530324
Dec 22 05:09:11.246: MGCP Packet sent to 192.100.64.11:2427--->
RSIP 252530326 *@R1.ccievoice.com MGCP 0.1
RM: graceful
Dec 22 05:09:11.250: MGCP Packet sent to 192.100.64.12:2427--->
RSIP 252530328 *@R1.ccievoice.com MGCP 0.1
RM: restart
Dec 22 05:09:11.254: MGCP Packet received from 192.100.64.11:2427--->
200 252530326
Login into CLI of the Publisher and Subscriber ( OS admin credentials ) and do a "utils network ping R1.ccievoice.com"
You can also use the ping utility from CUCM OS admin web page.
Manish
no cdp enable
Manish
Yes, you are right! I tried several times to change it into 0/1/0 by clicking the folder right next to the box. but the clicking only can open new page. I have not found where to change it. Can you give some suggestion? Ping is Ok between Pub/Sub to R1. Thank you
Do a "show diag" on the gateway and corresponding to that choose the correct slot, subslot and interface on cucm .
Manish
