12-17-2015 05:08 PM - edited 03-17-2019 05:17 AM
Hi The router HQ can ping the cucm. and I already set configuration in cucm. But the router cannot see the cucm. Please see the below. If more information is needed, please let me know. Thank you
HQ(config)#do sh ccm-m
MGCP Domain Name:
Priority Status Host
Primary None
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 20:34:52 UTC Dec 17 2015 (elapsed time: 04:22:51)
Last MGCP traffic time: 20:34:52 UTC Dec 17 2015 (elapsed time: 04:22:51)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul/Redundant link is down
FAX mode: cisco
Configuration Error History:
HQ(config)#
12-17-2015 05:13 PM
Amigo,
Can you post your complete config. also, what is the IP address(es) of your CUCMS?
Cheers
12-17-2015 05:21 PM
Thanks for your reply
HQ(config)#do sh run
Building configuration...
Current configuration : 1814 bytes
version 15.1
hostname HQ
boot-start-marker
boot-end-marker
card type t1 0 1
enable password
no aaa new-model
network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FHK0905F1FM
username admin password 0 admin
redundancy
controller T1 0/1/0
cablelength long 0db
channel-group 1 timeslots 24
controller T1 0/1/1
channel-group 1 timeslots 1-24
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 142.100.64.254 255.255.255.0
interface FastEthernet0/0.102
encapsulation dot1Q 102
ip address 142.102.64.254 255.255.255.0
interface FastEthernet0/0.202
encapsulation dot1Q 202
ip address 142.202.64.254 255.255.255.0
interface FastEthernet0/1
ip address 156.102.26.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0:1
no ip address
interface Serial0/1/1:1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
ccm-manager mgcp
ccm-manager config server 142.100.64.11
mgcp profile default
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
line con 0
line aux 0
line vty 0 4
password cisco
login local
transport input all
scheduler allocate 20000 1000
ntp source FastEthernet0/0
ntp master
end
12-18-2015 08:34 AM
When you say you "already set configuration in cucm", what do you mean by this? Did you configure an MGCP gateway?
In your config, i don't see where you configured the MGCP, try adding the line below:
mgcp call-agent 142.100.64.11 2427 service-type mgcp version 0.1
12-21-2015 12:35 PM
Thank you! I already got it
12-21-2015 02:20 PM
You need to add mgcp call agent and redundant if you have multiple nodes wants failover.
http://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/23966-mgcp-pri-cm.html
http://voiceonbits.com/2010/06/21/mgcp-gateway-setup/
https://supportforums.cisco.com/document/90521/mgcp-gateway-integration-cucm-and-pstn-service-provider
12-21-2015 02:59 PM
Excellent links Thank you
