routing 800 number to extension
tato386
Level 6
Level 6
I am trying to route an incoming call that was placed to our 800 number to a particular extension. I use a translation rule to redirect each DID to an extension or to the AA. However, when doing debugs on our PRI using "debug isdn q931" I see that the called number does not show the 800 number, rather it shows the DID of our main number and therefore it is redirected to the AA. How can I translate/redirect the incoming 800 calls to where I need them to go? Is there some other method or technique for this? I see a "redirecting number" in the debug. Can I use this? Or do I simply need to use a free DID and point the 800 to that and use my existing translation rules?
Diego
gogasca
Level 10
Level 10
diego
Telco will not use the 800 number DID normally, they translate it internally and give you the corresponding DID in your range.
Please check with Telco which number in fact they are using. if using H.323 you can use redirect number otherwise talk to telco to change the main number to other DID.
gogasca
Level 10
Level 10
diego
Ended up using a free DID to route the 800 number to.
Diego
