04-06-2012 01:49 PM - edited 03-16-2019 10:31 AM
I have CME v8.6 and have configured it for a PSTN ISDN/PRI. Outbound call are routing fine. The problem I am having is routing inbound DID's. On my test PRI the DNIS digits are 7. For example : 5551234 is what I am receiving. If I build an extension with extension number 5551234 the call routes in fine, I can answer and have 2-way audio. But I can't seem to route that 7 digit DNIS to an extension with a different number. So, what I want to do is this:
When someone dials 5551234 I want to route that call to ext. 1001, or some virtual extension that I build on all phones, etc. I guess I'm not building my translations correctly or have no idea what I am doing.
Any help?
Thanks.
Solved! Go to Solution.
06-19-2014 07:20 AM
The debug not give anything
The list of the test I have made
Router#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80007FFF
Number of L2 Discards = 0, L2 Session ID = 209
ISDN Serial0/1/0:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x8000001F
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
Router#
Router# debug isdn q921
ISDN Se0/0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=0
ISDN Se0/0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=0
ISDN Se0/1/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=5
ISDN Se0/1/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=5
Router#
Router#
Router#debug isdn q931
debug isdn q931 is ON.
Router#
06-19-2014 07:41 AM
Did you telnet into the router to do the debug? If you did you need to enablke terminal monitor...
router#term mon
then do the test again
06-19-2014 08:32 AM
This is my email: ***@yahoo.fr
Send me the test mail I will send you my whole configuration and we will have a quick look at this it possible
06-19-2014 07:53 AM
I connect to the router by two connexion
Console port and VTY with telnet, on telnet connection I have already type "terminal monitor but type it again and retry the test.
On the console port make a call again and but nothing is show
06-19-2014 07:57 AM
Do you see a debug output when you make an outbound call? If you do then the issue is likely that the inbound call is not hitting your gateway
06-19-2014 09:18 AM
With outboung call also, I don't have "debug isdn q931" screen showing appear on my console interface
06-19-2014 09:42 AM
ok..please try debug voip ccapi inout
06-19-2014 09:54 AM
06-20-2014 08:09 AM
There is no such number 22238408 in the logs. Is this the calling number or is this the number you called?
06-20-2014 08:59 AM
The router is actualy in production, that why their some call in other call showing. But my call are not appear in this log. I don't have eny signal during my call.
It is the line code on the E1 interce can cause this possible problem ?
06-25-2014 06:53 AM
I have a little analyse of my controller E1 0/0/0 interface. I think that I have a little idea about the my problem. I don't know the parameters of line code of ISDN Operator change it to 0 Error for all E1 controller parameters
The actual problem is the setting of three parameters on my controller:
linecode
clock source line primary
framing
Router#sh controller E1 0/0/0 brief
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (348 seconds elapsed):
0 Line Code Violations, 959 Path Code Violations
102 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
69 Errored Secs, 0 Bursty Err Secs, 102 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
23494 Line Code Violations, 22622 Path Code Violations,
1511 Slip Secs, 3 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins,
1077 Errored Secs, 0 Bursty Err Secs, 1414 Severely Err Secs, 80062 Unavail
Secs
Router#
There are two link who help me to find it:
http://www.cisco.com/c/en/us/support/docs/voice/h323/14081-voip-debugcalls.html
http://www.cisco.com/c/en/us/support/docs/wan/t1-e1-t3-e3/14149-chapter15.html
06-19-2014 10:08 AM
Ok, what number did you dial in this debug? called and calling number?
06-19-2014 10:19 AM
Me I make a call on the 22238408
As their where another IDNS PRI configuration on E0/1/0 perhaps they may be another call on this number
