03-07-2017 05:05 PM - edited 03-17-2019 09:44 AM
Hi All
We recently received alerts of LowSwapPartitionAvailableDiskSpace for our CUCM 10.5 and research suggest that we are hitting a bug CSCva41819 which did not suggest any workaround to clear this alert apart from monitoring it (_https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva41819/?referring_site=bugquickviewredir).
By chance you guys has a real workaround to resolve this alerts?
Fei
03-07-2017 05:33 PM
A restart of the server should clear the alert. Long term you will need to upgrade to a fixed release to permanently fix the problem.
Brandon
03-07-2017 05:38 PM
Brandon
Thanks for response. What could be impact if we leave this alerts going?
Fei
03-07-2017 05:48 PM
The swap partition is part of virtual memory and used as an overflow for physical RAM. The impact will likely be minimal. I would recommend you schedule a maintenance window to restart the server and put restarting on your list of regularly scheduled tasks.
Brandon
03-07-2017 08:04 PM
Will this alarm could cause phone reset itself randomly?
03-08-2017 06:04 AM
I suppose it's possible if the server runs out of physical memory and has no space on the swap drive to expand. I would recommend scheduling the restart before the swap drive runs out of space completely.
Brandon
03-24-2017 05:43 PM
Thanks Brandon.
We end up reboot impact nodes to bring swap partition disk space back to normal.
