Showing results forĀ
Search instead forĀ
Did you mean:Ā
RTMT PRI
Is there any way to generate an alert on a specific email in RTMT as soon as the
PRI goes down in cisco voice gateway
Ratheesh Kumar
Hi there
Try configuring the ā€œNumber of Registered Gateways Decreased" and you set the email address you want to receive the alert in RTMT.
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
Hi there
If you are running SIP check out this post
https://supportforums.cisco.com/t5/collaboration-voice-and-video/rtmt-create-alerts-base-on-common-scenarios-email-configuration/ta-p/3164139
For H323 you can use syslogs, snmp traps
Hope this helps!
Cheers
Rath!
Chris Deren
That would work for MGCP and SCCP GWs only as SIP or H323 do not register.
Your best bet is to perform the monitoring on the voice router via supported MIBs.
Hi chris,
We do have One MGCP and H.323 Gateway.what is the steps that we need to do in RTMT to add and activate notification when PRI is down in these 2 gateway.
