06-10-2012 06:46 AM - edited 03-16-2019 11:35 AM
I am running CUE on ISM 0/0, but I am not able to ping CUE IP address, please light me what I am missing in the below configuration.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/1.10
service-module fail-open
service-module ip address 10.1.1.41 255.255.255.0
service-module ip default-gateway 10.1.0.40
service-module mgf ip default-gateway 10.1.1.40
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.1.1.40 255.255.255.0
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.1.116.2 255.255.255.0
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
switchport access vlan 10
switchport mode trunk
no ip address
ip route 10.1.1.41 255.255.255.255 ISM0/0
int vlan 10
no ip add
06-10-2012 02:10 PM
ism0/0
Remove service-module mgf ip default-gateway 10.1.1.40
Change default gw address
service-module ip default-gateway 10.1.1.40
Remove the switch port access VLAN 10 and switch port mode trunk from ism0/1 and give it a try again.
06-11-2012 12:59 AM
Thanks for the reply, fine tune the configuration as per your suggestion, but I am not able to ping "service module Ip address 10.115.115.41", please let me know what we are missing in the below configuration ?
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
no ip address
shutdown
no ip address
duplex auto
speed auto
interface ISM0/0
service-module ip address 10.115.115.41 255.255.25
service-module ip default-gateway 10.115.115.40
no ip address
duplex auto
speed auto
ip address 10.115.115.40 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.115.115.40
interface ISM0/1
no ip address
06-11-2012 05:24 AM
Where are you trying to ping the ISM from?
Here is the basic configuration, this was pulled from a working CUE deployment..if this does not work then you may have issues elsewhere in your network.
interface Port-channel1
description # ETHER-CHANNEL to 3560 ##
no ip address
hold-queue 150 in
interface Port-channel1.10
interface ISM0/0
ip unnumbered Port-channel1.10
service-module ip address 192.168.1.10 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.1.1
interface ISM0/1
no ip address
ip route 192.168.1.10 255.255.255.255 ISM0/0
06-11-2012 08:53 AM
Could you please paste your physical gigabit interface configuration that connect CME router and Switch.
or if possible please paste you full configuration, which will help us a lot.
06-11-2012 09:08 AM
Are you able to ping from the router itself? On this deployment, I have an etherchannel from the 2921 to a 3560 switch so you will need to modify as necessary based on your topology. Here are all of the physical interface configurations..
no ip address
hold-queue 150 in
description # DATA #
ip nat inside
ip virtual-reassembly in
interface Port-channel1.101
description # VOICE #
encapsulation dot1Q 101
ip address 192.168.101.1 255.255.255.0
no ip address
shutdown
ip address X.Y.Z.W 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map CRYPTO_MAP_OUTSIDE
service-policy output VOICE_POLICY
interface ISM0/0
no ip address
duplex auto
speed auto
channel-group 1
no ip address
duplex auto
speed auto
channel-group 1
interface ISM0/1
no ip address
interface Vlan1
no ip address
06-11-2012 09:31 AM
I am not able to ping ISM 0/0 from router level itself ? with th above configuration.
06-11-2012 10:27 AM
If you could send me your entire configuration I can review but without some more information I won't be able to help you. If you have the ISM configured as above then it should work.
06-11-2012 10:43 PM
Routing related configuration pasted, I am not able to ping ISM from router itself.
hostname IP-Telephony
boot-start-marker
boot-end-marker
card type e1 0 3
no aaa new-model
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
no ipv6 cef
--More-- ip source-route
ip cef
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice translation-rule 5
rule 1 /.*\(8..\)$/ /\1/
--More-- !
voice translation-profile did
translate called 5
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/3/0
pri-group timeslots 1-10,16
--More-- !
interface Loopback0
ip address 142.1.66.254 255.255.255.255
ip pim dense-mode
no ip address
no ip address
duplex auto
speed auto
interface ISM0/0
service-module ip address 10.115.115.41 255.255.255.0
no ip address
duplex auto
speed auto
--More-- !
ip address 10.115.116.2 255.255.255.0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.30
encapsulation dot1Q 30
ip address 85.154.45.42 255.255.255.248
interface ISM0/1
no ip address
--More--
interface Vlan1
no ip address
interface Vlan10
no ip address
ip forward-protocol nd
ip http server
ip http access-class 15
ip http authentication local
no ip http secure-server
ip http max-connections 10
ip http timeout-policy idle 20 life 40 requests 10
--More-- ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 10.115.115.1
ip route 10.115.115.41 255.255.255.255 ISM0/0
control-plane
voice-port 0/3/0:15
translation-profile incoming did
mgcp profile default
sip-ua
mwi-server ipv4:10.115.115.41 expires 3600 port 5060 transport udp
gatekeeper
shutdown
--More-- telephony-service
sdspfarm units 2
sdspfarm transcode sessions 3
sdspfarm tag 1 sctran
sdspfarm tag 2 scconf
no privacy
conference hardware
max-ephones 50
max-dn 50
ip source-address 10.115.115.40 port 2000
auto assign 1 to 50
auto assign 1 to 40
service dss
system message Diners Club
url services http://10.115.115.40/voiceview/common/login.do
url authentication http://10.115.115.40/CCMCIP/authenticate.asp
cnf-file location flash:
load 7916-12 B016-1-0-4.SBN
load 7916-24 B016-1-0-4.SBN
load 7912 CP7912080004SCCP080108A.sbin
load 7945 SCCP45.9-2-1S.loads
load 7965 SCCP45.9-2-1S.loads
time-format 24
date-format dd-mm-yy
--More-- live-record 4250
voicemail 4220
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 142.1.66.254 10.115.115.40
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
night-service day Sun 17:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 08:00 07:59
night-service day Sat 08:00 07:59
create cnf-files version-stamp 7960 Jun 11 2012 08:03:07
ephone-template 1
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
--More-- softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer Confrn Acct Park
ephone-template 16
Telephony#
06-11-2012 10:49 PM
I am getting the following error as below:
Jun 12 09:41:53.050: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registra
tion Request
Jun 12 09:42:19.050: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registra
tion Request
06-11-2012 10:59 PM
HI
Send us folowing output
service-module ISM 0/0 status
Ronak Patel
06-11-2012 11:03 PM
Your ism module is in rommon mode (means not working properly). make the session in your ism module by following command.
router# service-module ism 0/0 session
then check whats appearing on the module.
Please rate if post is helpful.
06-11-2012 11:11 PM
The error message are as below, please let me know how to troubleshoot further ?
IP-Telephony#service-module ism 0/0 stat
% Ambiguous command: "service-module ism 0/0 stat"
IP-Telephony#
IP-Telephony#service-module ism 0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 131
Service Module is failed
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Module resource information:
CPU Frequency: 1068 MHz
Memory Size: 493 MB
Disk 0 Size: 4110 MB
No install/uninstall in progress
Local Partition Info - (0 apps)
Retrieving partition information
IP-Telephony#service-module ism 0/0 sess
IP-Telephony#service-module ism 0/0 session
Trying 10.115.115.40, 2131 ... Open
BIOS Build date: 10/16/2009
System now booting...
Authenticating boot loader....
Secondary Boot Loader authenticated - booting....
Please enter '***' to change boot configuration:
Detect and Initialze network device
Backup current platform configurations....
SRE step 1 - SM registration...
Response - no installation needed (len: 422)
SRE Installation Not Needed
Loading disk:/bzImage ... done.
Unable to load image
Unable to boot image
Initializing memory. Please wait...
Memory initialization OK. Continue...
DDR Memory 0512 MB detected
Genuine Intel(R) processor 1.06GHz
BIOS ISM 2.6, BIOS Build date: 10/16/2009
06-11-2012 11:38 PM
Install ftp and tftp program on your pc. and install ism from scratch. you should have ism image files on your pc.
06-11-2012 11:43 PM
Could you please give me the URL link and required software needed to install ISM.
