06-10-2012 06:46 AM - edited 03-16-2019 11:35 AM
I am running CUE on ISM 0/0, but I am not able to ping CUE IP address, please light me what I am missing in the below configuration.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/1.10
service-module fail-open
service-module ip address 10.1.1.41 255.255.255.0
service-module ip default-gateway 10.1.0.40
service-module mgf ip default-gateway 10.1.1.40
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.1.1.40 255.255.255.0
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.1.116.2 255.255.255.0
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
switchport access vlan 10
switchport mode trunk
no ip address
ip route 10.1.1.41 255.255.255.255 ISM0/0
int vlan 10
no ip add
06-11-2012 11:54 PM
send me output from follwoing commands
sh version
sh inventory
Dont forget to click on the rating.
06-13-2012 12:30 AM
IP-Telephony# sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M3,
EASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 17:09 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
IP-Telephony uptime is 1 week, 1 day, 0 minutes
System returned to ROM by reload at 11:37:10 UTC Sun May 13 2012
System restarted at 11:39:15 UTC Sun May 13 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at
Cisco CISCO2911/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FCZ1604700F
4 Gigabit Ethernet interfaces
11 Serial interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2911/K9 FCZ1604700F
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
IP-Telephony#
IP-Telephony#sh diag
Slot 0:
C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time 1w0d ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC15512Q7B
Hardware Revision : 1.0
Part Number : 73-11833-08
Top Assy. Part Number : 800-30797-04
Board Revision : B0
Deviation Number : 0
Fab Version : 03
Product (FRU) Number : CISCO2911/K9
Version Identifier : V05
CLEI Code : CMMBR00ARC
Processor type : C1
Chassis Serial Number : FCZ1604700F
Chassis MAC Address : c464.13f5.c7e0
MAC Address block size : 80
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 35 35 31 32 51 37 42 40
0x10: 06 18 41 01 00 82 49 2E 39 08 C0 46 03 20 00 78
0x20: 4D 04 42 42 30 88 00 00 00 00 02 03 CB 8C 43 49
0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 35 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 52 30 30 41 52
0x50: 43 09 C1 C2 8B 46 43 5A 31 36 30 34 37 30 30 46
0x60: C3 06 C4 64 13 F5 C7 E0 43 00 50 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply information
Top Assy. Part Number : 341-0235-05
PCB Serial Number : AZS15360093
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V03
Product (FRU) Number : PWR-2911-AC
CLEI Code :
Board Revision : A0
0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 05 88 00 00 00
0x10: 00 C1 8B 41 5A 53 31 35 33 36 30 30 39 33 03 00
0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8B 50 57
0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 00 00 00 00 00
0x40: 00 00 00 00 00 F3 00 59 41 00 BE 42 00 05 F8 00
0x50: 50 01 F4 17 2B 02 EE 1A 7A 03 E8 1B 65 04 E2 1C
0x60: 47 05 DC 1C C9 06 D6 1D A3 07 D0 1E 54 08 CA 1E
0x70: E6 09 C4 1F 5C 0A BE 1F BF 0B B8 20 12 0D AC 20
0x80: 92 0F A0 20 F0 11 94 21 38 13 88 21 6B 17 70 21
0x90: AE 1B 58 21 D3 1F 40 21 E0 23 28 21 DE 27 10 22
0xA0: 56 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Part Number : 73-11576-03
Board Revision : C0
Fab Version : 03
PCB Serial Number : FOC154820SE
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM3-16
Version Identifier : V01
0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 43 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 35 34 38
0x20: 32 30 53 45 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 3:
VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Top Assy. Part Number : 800-34657-01
Part Number : 73-13419-01
Board Revision : A0
Fab Version : 05
PCB Serial Number : FOC15476LPW
Product (FRU) Number : VWIC3-1MFT-T1/E1
CLEI Code : COUIA7PCAA
RMA History : 00
0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
0x10: 82 49 34 6B 01 42 41 30 88 00 00 00 00 02 05 C1
0x20: 8B 46 4F 43 31 35 34 37 36 4C 50 57 89 56 30 31
0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
Internal Services Module (ISM) Slot 0
Internal Services Module with Services Ready Engine
Internal Services Module is analyzed
Internal Services Module insertion time 1w0d ago
PCB Serial Number : FOC16041RT7
Part Number : 73-13417-01
Top Assy. Part Number : 800-34577-01
Fab Version : 04
Board Revision : A0
RMA History : 00
CLEI Code : IPUCAXHBAB
Product (FRU) Number : ISM-SRE-300-K9
Version Identifier : V02
0x00: 04 FF C1 8B 46 4F 43 31 36 30 34 31 52 54 37 40
0x10: 06 31 41 01 00 82 49 34 69 01 C0 46 03 20 00 87
0x20: 11 01 88 00 00 00 00 02 04 42 41 30 03 00 81 00
0x30: 00 00 00 04 00 C6 8A 49 50 55 43 41 58 48 42 41
0x40: 42 CB 8E 49 53 4D 2D 53 52 45 2D 33 30 30 2D 4B
0x50: 39 89 56 30 32 20 D9 03 40 C1 CB F3 00 06 40 05
0x60: F3 43 00 16 FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x80000000
Virtual address start of 2nd core memory : 0x0 - 0x0
2nd core configured disabled
L2 cache ways for 2nd core : 0
IP-Telephony#
IP-Telephony# sh telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_serie
s_home.html
protocol mode default
ip source-address 10.115.115.40 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
service dss
no auto-reg-ephone
max-ephones 50
max-dn 50
max-conferences 8 gain -6
dspfarm units 2
dspfarm transcode sessions 3
dspfarm 1 sctran
dspfarm 2 scconf
conference hardware
no privacy
no privacy-on-hold
hunt-group report delay 1 hours
Number of hunt-group configured: 1
hunt-group logout DND
max-redirect 10
voicemail 4220
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh music-on-hold.au
time-format 24
date-format dd-mm-yy
timezone 0 Greenwich Standard Time
secondary-dialtone 0
url services http://10.115.115.40/voiceview/common/login.do
url authentication http://10.115.115.40/CCMCIP/authenticate.asp
call-forward pattern .T
transfer-pattern .T
night-service day Sun 17:00 08:05
night-service day Mon 17:00 08:05
night-service day Tue 17:00 08:05
night-service day Wed 17:00 08:05
night-service day Thu 17:00 08:05
night-service day Fri 08:00 07:59
night-service day Sat 08:00 07:59
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message Diners Club
web admin system name cisco password cisco
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 May 13 2012 13:14:02
transfer-system full-consult
transfer-digit-collect new-call
multicast moh 239.1.1.1 port 16384
route 142.1.66.254
10.115.115.40
auto assign 1 to 50
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
IP-Telephony#
IP-Telephony# sh inventory
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9 , VID: V05 , SN: FCZ1604700F
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlo
3", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1 , VID: V01 , SN: FOC15476LPW
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP
IMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN: FOC154820SE
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "
nternal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9 , VID: V02 , SN: FOC16041RT7
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC , VID: V03 , SN: AZS15360093
06-13-2012 12:37 AM
Goto downalods page of cisco and download these files. You have to have valid CCO credentials to download.
cue-installer.sme.8.5.1
cue-vm-en_US-langpack.sme.8.5.1.prt1
cue-vm-full-k9.sme.8.5.1.prt1
cue-vm-installer-k9.sme.8.5.1.prt1
cue-vm-k9.sme.8.5.1.key
cue-vm-k9.sme.8.5.1.pkg
cue-vm-k9.sme.8.5.1.pkg.install.sre
cue-vm-k9.sme.8.5.1.pkg.install.sre.header
cue-vm-langpack.sme.8.5.1.pkg
If you find this post helpful, Click on rating!!!
06-18-2012 06:19 AM
D you have a host route to your service module address?
Sent from my iPad
06-18-2012 10:10 PM
Yes as below:
ip route 10.115.115.41 255.255.255.255 ISM0/0
