Running DMA from CUCM 8.6 on UCS Chasis
Madhukar Tyagi
Hi All,
I am seeing a help on upgrading the CUCM 8.5 on UCS platform.
I will be upgrade the 4.x CUCM to 8.6.
I understood, 4.x backup will be migrated with the help of DMA tool. During the 8.6 installation, I need to select the upgrade option and select the DMA from SFTP or FTP.
Only concerning area is -- UCS does not support USB port. We need to supply the platformconfig.xml file through FLP media.
1- Do we have FLP drive installed at UCS-C210M2-VCD2 chasis.
2- Is there other way, System will not look to platformconfig.xml file and allow me to enter the required information manaully.
Pls advise.
Rgds,
Madhukar Tyagi
Joseph Martini
If you use the answer file generator (for the platformconfig.xml) you're correct you have to use an FLP "The answer file generated by the Answer File  Generator (platformConfig.xml) cannot get read from a USB key to perform  an unattended installation. Instead, you must put the answer file into a  FLP image to be mounted in the floppy drive."
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html
As for DMA you will have to upgrade to 7.x first, since you cannot import a DMA file to CUCM 8.x (
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp57448).
Hello Joe,
Thank You for reply.
Please confirm
1- Do we have the FLP drive installed in the UCS-C210M2-VCD2 chasis as a defualt config.
2- Is there any way, I can aviod the Answer generator file and enter the confguration manaully during 7.1.3 installation.
BOM details are
UCS-C210M2-VCD2Bare Metal UCS C210M2 Svr.,2xE5640 CPU,48GB RAM,10x146GB HDD
CAB-N5K6A-NAPower Cord, 200/240V 6A North America
UC-A01-X01092.66GHz Xeon E5640 80W CPU/12MB cache/DDR3 1066MHz
UC-A03-D146GC2146GB 6Gb SAS 15K RPM SFF HDD/hot plug/drive sled mounted
UC-N01-M304GB14GB DDR3-1333MHz RDIMM/PC3-10600/dual rank 1Gb DRAMs
UC-N2XX-ABPCI03Broadcom BCM5709 Quad Gig E card (10/100/1GbE)
UC-R210-ODVDRWDVD-RW Drive for UCS C210 M1 Rack Servers
UC-R2X0-PSU2-650W650W power supply unit for UCS C210 M1 Rack Server
UC-R2XX-PL003LSI 6G MegaRAID PCIe Card (RAID 0, 1, 5, 6, 10, 60) - 512WC
CON-UCS3-C210M2VCUC SUPPORT 24X7X4 Bare Metal UCS C210M2 Svr.,2xE5640 CPU,4
Rgds,
Madhukar Tyagi
