Running out of MTP resources, Conf and Trnsfr frequent Problem
Criss Sawyer
Hi all,
i have  a CUCM Cluster that contains 3 server  running 7.1.5. we have until up to 700 iphones deployed. we noticed that  freaquent problem with conference and transfer. when i checked MTP  resources through RTMT i've noticed that all resources are active (24  per server). i figure that could be the reason behind that problem
customer required that conf and transfr should be allowed for ipphones.
i don't if there any way we can deal with this problem.
Many thx
Best regards,
Brian Meade
Level 7
Level 7
Add some hardware resources.
i have 24 MTP per server is that means i can only make 24 transfer at the same time?
the only hardware lefts in our environement is the voice gateway. How can i cheched that DSP resources in the gateway is enough for Medio Resources and voice call at the same time?
Do a sh voice dsp and a sh diag and compare what HW you have and what's currently in use.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
