SAF Learned Pattern Error in RTMT
shakkeerb
I am using CUCM 9.1 and configured SAF between CUCM Cluster and CMEs. All CMEs are learning the patterns and inter calls are successfully made. CUCM side, SAF forwarder is learning the patterns also advertising. But I cannot see any learned pattern in RTMT. I am receiving an Error while checking both SAF learned Patterns and SAF Forwarders. Error Message is " An Error Occured While processing". What may be the reason and how can i resolve it?
I attach Screen shot of the Error Message.
Guillermo_87
Try to run the application Run as administrator from the pc
Guillermo_87
