SCCP Admin State: DOWN
Rakesh K
Hi Everyone,
I am getting error "SCCP Admin State: DOWN"
call manager IP 10.106.97.240
Please suggest how to fix the issue.
R3925#sh running-config
Building configuration...
Current configuration : 4283 bytes
! Last configuration change at 13:37:35 UTC Sun Nov 12 2017
version 15.3
hostname R3925
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
card type e1 0 1
no logging console
no aaa new-model
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
R3925#wr mem
[OK]
R3925#
R3925#
R3925#
R3925#
R3925#
R3925#
R3925#config t
Enter configuration commands, one per line. End with CNTL/Z.
R3925(config)#
R3925#sh run
! Last configuration change at 14:04:38 UTC Sun Nov 12 2017
version 15.3
hostname R3925
boot-start-marker
boot-end-marker
card type e1 0 1
no logging console
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 10.106.97.240
ipv4 10.106.110.8
ipv4 10.106.106.100
ipv4 10.106.97.202
ipv4 10.106.97.241
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
bind control source-interface gig0/0
bind media source-interface gig0/0
license udi pid C3900-SPE150/K9 sn FOC152556W0
license accept end user agreement
license boot module c3900 technology-package securityk9
license boot module c3900 technology-package uck9
license boot module c3900 technology-package datak9
hw-module pvdm 0/0
hw-module sm 2
username admin privilege 15 password 0 cisco!123
redundancy
controller E1 0/1/0
pri-group timeslots 1-31
ip ftp username None
ip ftp password None
ip tftp blocksize 8192
interface Loopback0
no ip address
shutdown
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.106.110.8 255.255.255.224
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.106.110.8
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface GigabitEthernet2/0
no ip address
shutdown
interface GigabitEthernet2/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.106.110.1
ip route 3.3.3.1 255.255.255.255 GigabitEthernet0/0
ip route 3.3.3.3 255.255.255.255 GigabitEthernet0/0
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/1/0:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.106.97.241 identifier 1 priority 1 version 7.0
sccp ccm 10.106.97.240 identifier 2 priority 2 version 7.0
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register CorpHq-Hw-Conf
associate profile 1 register CorpHq-Sw-Mtp
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum conference-participants 16
maximum sessions 1
associate application SCCP
dspfarm profile 1 mtp
codec g729r8
codec g729ar8
rsvp
stun firewall-traversal flowdata
maximum sessions software 50
dial-peer voice 5 voip
destination-pattern 5555
session protocol sipv2
session target ipv4:10.106.97.240
dial-peer voice 7 pots
destination-pattern 4...
no digit-strip
port 0/1/0:15
dial-peer voice 4 pots
incoming called-number .
port 0/1/0:15
sip-ua
gatekeeper
shutdown
line con 0
exec-timeout 60 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
end
R3925#
R3925#
R3925#
R3925#
R3925#sh sccp
R3925#sh sccp
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 10.106.110.8
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.106.97.241, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
Call Manager: 10.106.97.240, Port Number: 2000
Priority: 2, Version: 7.0, Identifier: 2
6 Replies 6
Chris Deren
Have you tried issuing "no sccp", "sccp"?
yes I have tried, but it didn't work
Are the CUCM servers you point to the same server used in the CUCM Group assigned to the device pool of the media resources in CUCM?
Normally you would see "sccp" in the "sh run", I don't see it in your config.
I just deleted the router from the call manager and added it back and it worked
Try to reload the router and apply sccp command after that.
Me funciono y el sccp subió
