Schedule for Outbound Calls
JaredKa
Is there a feature that allows for outbound calls from my PBX using the Allow CSS during an open period, and then during the closed period I can use a closed CSS?  I work for a hospital and our behavioral medicine wants to see if this can be done for patient phones.
I started to look into the Time Period Class of Control, but it seems that it might refer to inbound calls.
Maybe I'm wrong. Any advice would be helpful.
You would definitely be able to use the time of day configuration elements in CM for this. It’s use case is not limited into any direction, it can be used for outbound or inbound calls.
Response Signature
As @Roger Kallberg  mentioned use Time of the Day Routing. Below guide explains how to configure, but the guide is from incoming.
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/109588-tod-routing-example00.html
Response Signature
TONY SMITH
CUCM Time of Day Routing applies to Partitions.  So you'd have a single CSS, but some of the Partitions listed would only be visible during your selected hours.
