Showing results forĀ
Search instead forĀ
Did you mean:Ā
Screen Lock IP Phone 8800 series !!!
eng_tareq
Hello Community,
Actually i have simple question become not easy to solve !!
Is there any way to screen lock 8841 ip phone ??
Please excuse me if it very simple but i tried many way and non is working?
2 Accepted Solutions
Deepak Rawat
http://docwiki.cisco.com/wiki/Endpoints_FAQ#Can_I_lock_my_phone.2C_or_require_a_PIN_before_making_calls.3F.3F
Deepak
Hi Tareq,
This is possible using 3rd Party XML Applications. You can check here:
http://www.commsouth.com/downloads/PhoneApplications_XMLServices_Brochure_EN.pdf
http://www.commsouth.com/UCC-Applications.php
If you require more information, please do let me know.
Prasana Kumar. P (prasana@commsouth.com)
Please rate if useful.
Regards, Prasana Kumar.P +919841027006
Deepak Rawat
Deepak
Dear All,
Can I lock my phone, or require a PIN before making calls??
No, neither of those are options provided by CUCM. The only options we offer for such purposes, would be to use EM, FAC, or CMC. If you want this, you would need to use a 3rd party app.
Hi Tareq,
Few clarities regarding:
EM - Extension Mobility, this is used like login/logout from you phone and applies your EM profile. In your CUCM you will have to create an EM XML service though.
FAC - Forced Authorization Code - Is basically used when you dial out a external PSTN call and used for billing purpose and tracking of calls who has made from which extenions.
CMC - Client Matter Code - Same like above FAC.
What i have mentioned in my pervious chat message is that, you can lock the Phone using a PIN which is based on XML Application services and you can control the unauthorized use of the device.
Prasana
Hi Tareq,
