Secondary dial tone
opnineopnine
hi all
I have a customer that to dial a number out to the PSTN, he dials 9. xxxx but know they want to change it to 8.xxxx, My question is that changing the route patterns will be enough? Or I have to make some other changes?
Thanks.
Jaime Valencia
Assuming there's nothing that could overlap with 8, yes, that would be it.
java
if this helps, please rate
That's also assuming they're currently stripping pre-dot.  If H.323, a lot of times you make your dial-peers on the gateway include the 9 so you can re-use the same dial-peers for SRST.  If that's the case, he may need to update those as well.
