Secondary number on IP Phone 9971
Edson Vuma
Hi, guys.
Is it possible to configure a secondary number (to use DID [Direct Inward Dialing]) on an IP Phone 9971 using SIP on my network?
For example, my extension number (Internally) is 11.
I want to set a number so that anyone ( Out of my office) can call me through PSTN using a ISDN PRI line. Using a secondary number (Direct Inward Dialing or DID).
I've configured on SCCP phones (6921 and 7942/7962) and it works perfectly. Is a simple configuration, but I cant find a way to config it on SIP phones.
Here the example for SCCP Phones configuration:
CME(config)#ephone-dn  12  dual-line
number 12 secondary 2xxxxxxx
label phoneLabel
name phoneName
How to add a secondary number on 9971?
Any help?
Edson Vuma
-- Regards Edson Vuma
Jorge Armijo
Level 4
Level 4
Hi Edson,
There's no such thing as secondary number for the voice register dn's, unfortunately, seems that the option is just for SCCP phones, what you can do, is to create translation-rules to macth the DID with the extension number, if that is the case:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
Jorge Armijo
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Edson Vuma
This question is done:
Just add two dn and on one of them, add this second number.
voice register pool  1
busy-trigger-per-button 10
id mac
type 9971
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
codec g711ulaw
voice register dn  1
number 01   ← Internal number
allow watch
voice register dn  2
number 21359045    ← External number, on this case I used a example number with the prefix 21 (local prefix in Maputo-Mozambique).
create profile.
And its now working.
Edson Vuma
Edson Vuma
