External number on IP Phone 9971
Edson Vuma
Guys,
Im facing an issue...I've configured correctly, but cant configure an external (secondary) number for 9971.
Any help?
Edson Vuma
-- Regards Edson Vuma
8 Replies 8
Andrew Skelly
Level 7
Level 7
What exactly are you trying to do?  Are you referring to the external mask, or are you referring to the ability to have a second line on the 9971?
You said you've configured correctly, but can't configure.
Please rate helpful posts by clicking the thumbs up!
Andrew
Is a second line on the 9971.
For examble...on SCCP phones, to create a secondary number, I made like this:
ephone-dn  11  dual-line
number 12 secondary 2xxxxxxx
label phoneLabel
name phoneName
I would like to add a "secondary number" to the 9971, which uses SIP.
Edson Vuma
Any help?
Edson Vuma
What version of UCM are you using?
He is using CME based on the snippet of config posted.
Edson,
Use translation profiles to mask caller ID appropriately.
Chris
Chris
Would you be more specific.
Sorry
Im not familiar with translation profiles.
Thanks for your help
Edson Vuma
Hi Edson,
There's  no such thing as secondary number for the voice register dn's,  unfortunately, seems that the option is just for SCCP phones, what you  can do, is to create translation-rules to macth the DID with the  extension number, if that is the case:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
Jorge Armijo
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Edson Vuma
This question is done:
Just add two dn and on one of them, add this second number.
voice register pool  1
busy-trigger-per-button 10
id mac
type 9971
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
codec g711ulaw
voice register dn  1
number 01   ← Internal number
allow watch
voice register dn  2
number 21359045    ← External number, on this case I used a example number with the prefix 21 (local prefix in Maputo-Mozambique).
create profile.
And its now working.
Edson Vuma
