Securing Voice Gateway, Problem with some commands (Not Exist!)
I need to secure voice gateway, but i can't use some commands to enable it as
>>voice service voip
sip
session transport tcp tls
also
>>sip-ua
crypto signaling remote-addr x.x.x.x 255.255.255.255 trustpoint VGW
both commands don't exist at all when I write "?"
the only exist >>session transport TCP
VGW is ISR 4351 v16.6.4
license boot suite advUCSuiteK9
license boot suite foundationSuiteK9
Before Activation those commands where not available.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
jlrvg(config)#sip-ua
jlrvg(config-sip-ua)#cr
jlrvg(config-sip-ua)#credentials ?
After the activation the commands you mentioned   are available.
FoundationSuiteK9     FoundationSuiteK9     EvalRightToUse FoundationSuiteK9
securityk9
appxk9
AdvUCSuiteK9          AdvUCSuiteK9          EvalRightToUse AdvUCSuiteK9
uck9
cme-srst
cube
jlrvg(conf-serv-sip)#session transport tcp tls
Response Signature
Jaime Valencia
Do you have both, uc and security, licenses enabled in the ISR?
java
if this helps, please rate
yes,
AdvUCSuiteK9
>>sh version
securityk9
appxk9
AdvUCSuiteK9 AdvUCSuiteK9 Permanent AdvUCSuiteK9
uck9
cme-srst
cube
>>sh license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: uck9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Suite: AdvUCSuiteK9
License Priority: Medium
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
securityk9
appxk9
uck9
cme-srst
cube
securityk9
appxk9
uck9
cme-srst
cube
Response Signature
Hi Nithin,
you are amazing.
it works now.
I really appreciate your help with all the detailed information to describe the issue and its solution.
