01-29-2011 03:15 AM - edited 03-16-2019 03:09 AM
Referring to the topology in the attached diagram
I would like to know how it is possible to send a fax from Site B (Branch) using the PSTN line of Site A (Head Office) over the WAN
What are the commands and configuration
I can make phone calls over the WAN using the Cisco Communications Manager Express on the router and everything is working fine
01-29-2011 03:43 AM
Can you make PSTN call from site B through the router in. esite A? If yes then you can make fax calls too as fax basically starts with a voice call. You need to deternimne what fax protoco;l you want to use. T.38 or passthrough? What fax signalling do you want to use? NSE or signalling? It all depends. Since you are passing the calls over the WAN, you need to know if you have enough bandwidth for additional fax calls. Passthroug uses G.711 which is about 64kbps. T.38 uses G.729 which is about 8kbps.
01-29-2011 04:08 AM
Message was edited by: nascoentr
01-29-2011 04:12 AM
01-30-2011 02:21 PM
Cisco fax protocol is not T38. Cisco fax is their own protocol and T38 is an industry standard.
I would advise using T38 rather than cisco fax, cisco themselves recommend T38 and if you use PVQM3 memory in your routers then cisco fax isn't even supported.
01-30-2011 02:27 PM
The configuration would be something like this:
dial-peer voice 1 voip
destination-pattern . (this will match anything)
session target ipv4:10.200.72.37 (this is the IP on my CCME on site A)
fax protocol t38
