Service cannot be Activated or Deactivated due to Database Update Failure
Nguyen KeThuc
Hi all,
I am using CUCM version 7.1. After I install subscribers, I can not start any services in Sevice Activation page. The publisher is ok. Error message:
"...Service cannot be Activated or Deactivated due to Database Update Failure".
Any ideas for me.
27 Replies 27
Aman Soi
Hi Thuc,
What is the exact CUCM version u are using?
can u share the output of utils dbreplication runtimestate  or from Cisco Unified Reporting , shgare DB status report?
regds,
aman
I am using version 7.0.2.10000-18. Out put of utils dbreplicate status:
admin:utils re
      utils remote_account
      utils reset_ui_administrator_name
      utils reset_ui_administrator_password
admin:utils db
admin:utils dbreplication
      utils dbreplication clusterreset
      utils dbreplication dropadmindb
      utils dbreplication forcedatasyncsub
      utils dbreplication repair
      utils dbreplication reset
      utils dbreplication setrepltimeout
      utils dbreplication status
      utils dbreplication stop
admin:utils dbreplication st
admin:utils dbreplication stat
admin:utils dbreplication status
This command reads and writes database information from all machines and will take quite some time...please be patient.
-------------------- utils dbreplication status --------------------
Output is in file cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_11_05_56.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_11_05_56.out " command to see the output
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_11_05_56.out
connect to cucmsub1_ccm7_0_2_10000_18 failed
Enterprise Replication not active  (62)
command failed -- unable to connect to server specified  (5)
No Errors or Mismatches found.
Replication status is good on all available servers.
utils dbreplication status output
To determine if replication is suspect, look for the following:
        (1) Number of rows in a table do not match on all nodes.
        (2) Non-zero values occur in any of the other output columns for a table
connect to syscdr@cucmsub1_ccm7_0_2_10000_18 failed
Error Details:
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1 - 20 of 32) :
admin:
Thuc
Hi Thuc,
Please refer the link for resolving DBReplication problem.Was this working earlier or faced the replication problem now
https://supportforums.cisco.com/docs/DOC-13672
From Cisco Unified Reporting , can u share the snapshot of CM Database Status report.
regds,
aman
Please review screen capture for DB reporting:
Thuc
Hi Thuc,
It seems that you have three servers in a cluster out of which two Subscribers are facing the issue of DBReplication.
Can u try the commands to fix the issue.
  1. utils dbreplication stop on all subscribers. This command can be run on all subscribers at the same time but needs to complete on all subscribers prior to being run on the publisher. The amount of time this command takes to return is based on your cluster's repltimeout. This can be seen through the Command show tech repltimeout and by default is 300 seconds or 5 minutes. At the end of this document I will provide a calculation for determining what you should set your repltimeout (via utils dbreplication setrepltimeout) in your cluster and how this value affects replication.  (If utils dbreplication stop all is available (7.X and later) then step 1 and step 2 can be accomplished in this one command)
  2. utils dbreplication stop on publisher.  Again this command can be done through the utils dbreplication stop all if available.  This also will wait the repltimeout as said above.
  3. utils dbreplication reset all - This command will take an hour to complete or longer depending on your cluster. You can monitor the status through the utils dbreplication runtimestate or through the procedure following the examples portion of this document.
You won't be able to use utils dbreplication rumtimestate. So, use Cisco unified reporting tool to check the Count.It should be 2 if replication is fine.[Expand View details]
regds,
aman
Hi Aman,
Thanks for help.
I tried to fix DB replication issue. But I still can not activate any services.
Output is in file cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_12_36_13.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_12_36_13.out " command to see the output
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_02_12_36_13.out
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_cucmpub_ccm7_0_2_10000_18    2 Active   Local           0
g_cucmsub1_ccm7_0_2_10000_18    3 Active   Connected       0 Jul  2 11:32:03
command failed -- undefined  replicateset  (11)
Error Details:
        The specified replicate name does not exist.
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1 - 20 of 26) :
admin:
I also resintalled one subscriber with same IP address and Hostname. It is working fine. The other one is kept troubleshooting.
How about the log file to diagnose the activation issue? Could you suggest for  me?
Tha
Hi Thuc,
Was this working setup ?
Hope u have enough Node Licenses on Call manager and u have added SUb2 in Pub.
regds,
aman
Hi Aman,
I checked the license report:
With rebuilded subscriber server, now I can activate the services.
Thuc
Hi Thuc,
Thanks for update.
Finally , u had to rebuild both the subscribers.
regds,
aman
Hi Aman,
So, I want to find why I can not activate the services. Could you suggest me for log trace or debug or something like that?
Thuc.
Hi Thuc,
Now, since u have re-installed  SUB, u won't be able to get the logs.
regds,
aman
I just rebuilded one subscriber server. The other is still there. We can get the log files if we want.
Thuc
Hi Thuc,
I thought u have rebuilt the second SUB as well.
Please follow the link to enable traces.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
regds,
aman
Hi Thuc,
Please provide the snapshot from
Cisco unified reporting tool  -> Database Status -> Replication Server List
regds,
aman
