Setting up a Cisco Ip phone 8832 but I can't find it in CUCM
MeisnerC
I went to set up a 8832 phone and discovered I can't seem to find any reference of the device within CUCM.
We are running System version: 11.5.1.13902-2
I'm not sure if this is a version issue or if I'm missing something.
Not sure what other information I need to add to this discussion.
If you need additional info please let me know.
Jaime Valencia
Either upgrade to the latest SU or install the required DevPack for the device to be available.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix.html
java
if this helps, please rate
Jaime Valencia
java
Jamie,
Thank you very much. I will install the DevPack for this device.
I appreciate the help.
