Setting up BRI
Dear friend.
I have some problem when setting up BRI Interface (2B+D) in Vietnam.
This is my configuration:
Configuration:
interface BRI0/1/0
no ip address
no ip route-cache
isdn switch-type basic-net3
isdn twait-disable
isdn tei-negotiation preserve
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
end
Show ISDN Status:
ISDN BRI0/1/0 interface
        dsl 4, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 4 CCBs = 0
    The Free Channel Mask:  0x80000003
Debug ISDN Q921:
debug isdn q921
debug isdn q921 is              ON.
Jan 31 04:38:23.695: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Jan 31 04:38:23.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan 31 04:38:24.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan 31 04:38:25.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan 31 04:38:26.291: ISDN BR0/1/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jan 31 04:38:26.291: ISDN BR0/1/0 Q921: User TX -> IDCKRP ri=18285 ai=0
Jan 31 04:38:26.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Debug ISDN Q931:
Jan 31 04:47:39.707: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan 31 04:47:45.707: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan 31 04:47:51.707: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Debug ISDN error interface BRI 0/1/0
Jan 31 04:52:26.607: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
        L2: sapi 63 tei 127 ces 0 ev 0x3
Jan 31 04:52:26.611: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
        L2: sapi 63 tei 127 ces 0 ev 0x650
Jan 31 04:52:27.631: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Jan 31 04:52:27.707: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Jan 31 04:52:33.707: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Jan 31 04:52:33.895: ISDN BR0/1/0 SERROR: service_queue_from_physical_layer: got ISDN_PH_ACT_IND on an active interface?
Please help me to solve this problem.
I can't make call to PSTN.
Thanks all my friends.
VinhPLT
23 Replies 23
Dear Paolo.
Thanks for your information.
I'll check it tommorrow.
Best Regards.
VinhPLT
But can you please tell me why BRI interface up when I connect both of device to NT1.
Regards.
VinhPLT
Dear friend.
The BRI interface has been up but I can't make call through it.
I have result with command debug ISDN when I make call:
Feb  4 09:09:52.871: ISDN BR0/1/1 EVENTd: isdn_get_guid: Got Guid 00115EE30C00
Feb  4 09:09:52.871: ISDN BR0/1/1 EVENT: process_bri_call: call id 0x8016, called_number 427, Guid 00115EE30C00 speed 0, call type VOICE, bchan -1 clng_num 700Received pdata len 0x3B data:1C 39 9E 1 0 3 67 74 64 0 0 0 2E 49 41 4D 2C D A 47 43 49 2C 30 30 31 31 35 65 65 33 35 33 31 38 66 31 31 30 30 63 30 30 63 30 30 31 30 61 65 38 34 38 32 38 D A D A
Feb  4 09:09:52.871: ISDN BR0/1/1 EVENTd: process_bri_call: No name in GTD
Feb  4 09:09:52.871: ISDN Se0/0/0:15 EVENTd: isdn_get_display_text_from_gtd: false ret
Feb  4 09:09:52.871: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x17 is 0x0 0x0, Calling num 700
Feb  4 09:09:52.871: ISDN BR0/1/1 EVENTd: calltrkr_setup_received: isdn_info=721130452l, call_id=0x8016 ORIGINATE
Feb  4 09:09:52.871: ISDN BR0/1/1 EVENTd: calltrkr_setup_received: calltracker disabled
Feb  4 09:09:52.871: ISDN BR0/1/1 Q931: Sending SETUP  callref = 0x0091 callID = 0x8016 switch = basic-qsig interface = User
Feb  4 09:09:52.871: ISDN BR0/1/1 Q931: TX -> SETUP pd = 8  callref = 0x0091
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0081, '700'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '427'
Feb  4 09:09:58.871: ISDN BR0/1/1 Q931: TX -> SETUP pd = 8  callref = 0x0091
                Standard = CCITT
Feb  4 09:10:04.871: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0091
        Cause i = 0x80E6 - Recovery on timer expiry
Feb  4 09:10:04.871: ISDN  EVENTd: cc_clear_free_list freeing 0x2AF92C28
Feb  4 09:10:04.871: ISDN BR0/1/1 EVENT: process_rxstate: ces/callid 1/0x8016 calltype 2 HOST_DISCONNECT_ACK
Feb  4 09:10:04.871: ISDN BR0/1/1 EVENTd: process_rxstate: cause=0x66 (102), cause_present=1
Feb  4 09:10:04.871: ISDN BR0/1/1 EVENTd: calltrkr_call_cleared: isdn_info=0x2AFB93D4, call_id=0x8016
Feb  4 09:10:04.871: ISDN BR0/1/1 EVENTd: calltrkr_call_cleared: hndl=0, cause=102, Recovery on timer expiry
Feb  4 09:10:04.871: ISDN  CDAPI: cdapi_find_tsm found a GTD message RLC,
PRN,isdn*,,,
Do you have any idea?
Are you trying to call 427 from Cisco to PBX ?
If so that is not the right configuration.
Hi Paolo.
That's right.
This is my configure.
Can you help me to check it
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2109617910
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2109617910
revocation-check none
rsakeypair TP-self-signed-2109617910
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
voice class h323 1
  h225 timeout tcp establish 3
license udi pid CISCO2911/K9 sn FGL1650115F
hw-module pvdm 0/0
username cisco privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
controller E1 0/0/1
pri-group timeslots 1-2,16
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.28.90.60 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.232.72.39 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.232.72.39
interface GigabitEthernet0/2
description $ES_LAN$
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
ip flow ingress
ip flow egress
encapsulation hdlc
isdn timer T310 1000
isdn overlap-receiving T302 3000
isdn incoming-voice modem
isdn T309-enable
isdn send-alerting
isdn bchan-number-order ascending
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
isdn incoming ie redirecting-selection first
no cdp enable
interface Serial0/0/1:15
no ip address
ip flow ingress
ip flow egress
encapsulation hdlc
isdn send-alerting
isdn sending-complete
no cdp enable
interface BRI0/1/0
no ip address
no ip route-cache
isdn protocol-emulate network
isdn layer1-emulate network
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/1/1
no ip address
isdn switch-type basic-qsig
isdn timer T310 400000
isdn twait-disable
isdn static-tei 0
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.232.72.254
access-list 23 permit any
control-plane
voice-port 0/0/0:15
connection plar 713
voice-port 0/1/0
compand-type a-law
voice-port 0/1/1
voice-port 0/0/1:15
mgcp profile default
dial-peer voice 700 voip
description *****Dial-peer to CRM*****
destination-pattern 7..
session target ipv4:10.232.72.31
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1 pots
destination-pattern 01.........
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 3 pots
destination-pattern [2-7].......
direct-inward-dial
port 0/0/0:15
dial-peer voice 4 pots
destination-pattern 0[2-7]........
direct-inward-dial
port 0/0/0:15
dial-peer voice 5 pots
destination-pattern 0[2-7].........
direct-inward-dial
port 0/0/0:15
dial-peer voice 300 pots
destination-pattern 3..
direct-inward-dial
port 0/0/0:15
dial-peer voice 600 pots
destination-pattern 6..
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 2 pots
destination-pattern 0983995012
direct-inward-dial
port 0/1/1
forward-digits all
dial-peer voice 154 pots
destination-pattern 427
direct-inward-dial
port 0/1/1
forward-digits all
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
BR,
VinhPLT
Hi Paolo.
That's right.
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
voice service voip
h323
sip
voice class h323 1
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
controller E1 0/0/1
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
no ip address
ip flow ingress
ip flow egress
encapsulation hdlc
isdn T309-enable
isdn send-alerting
no cdp enable
no ip address
ip flow ingress
ip flow egress
encapsulation hdlc
isdn send-alerting
no cdp enable
interface BRI0/1/0
no ip address
no ip route-cache
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn twait-disable
isdn static-tei 0
ip http server
control-plane
voice-port 0/0/0:15
connection plar 713
voice-port 0/1/0
compand-type a-law
voice-port 0/1/1
voice-port 0/0/1:15
no vad
direct-inward-dial
port 0/0/0:15
direct-inward-dial
port 0/0/0:15
direct-inward-dial
port 0/0/0:15
direct-inward-dial
port 0/0/0:15
direct-inward-dial
port 0/0/0:15
direct-inward-dial
port 0/1/1
forward-digits all
direct-inward-dial
port 0/1/1
forward-digits all
direct-inward-dial
port 0/1/1
forward-digits all
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
BR,
VinhPLT
To connect router to PBX, make a crossed cable and network-side configuration.
There are many posts about about.
As I said before, you will loose much time in trying to do yourself, hire a reputable consulant or person with expereince.
BRI Interface is up!
ISDN BRI0/1/1 interface
        dsl 5, interface ISDN Switchtype = basic-qsig
         **** Slave side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
    Active dsl 5 CCBs = 0
    Total Allocated ISDN CCBs = 0
I must do it by myself.
BR.
VinhPLT
Debug ISDN when I call from 427(PBX) to 700(PBX)
Feb  4 09:31:57.751: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0x8A
                Exclusive, B2
        Facility i = 0x91AA068001008201008B0100A10E02021B2506042B0C092903020780
        Facility i = 0x91AA068001008201008B0102A11402021B2602013B300B30090A01050A01040A0103
        Facility i = 0x91AA068001008201008B0100A10C02021B2706042B0C09008400
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0183, '427'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x80, '700'
        Locking Shift to Codeset 5
        Codeset 5 IE 0x32  i = 0x81
Feb  4 09:32:01.687: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
        Cause i = 0x81E6 - Recovery on timer expiry
Feb  4 09:32:01.763: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Facility i = 0x91AA068001008201008B0102A11402021B2D02013B300B30090A01050A01040A0103
        Facility i = 0x91AA068001008201008B0100A10C02021B2E06042B0C09008400
Feb  4 09:32:05.699: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
