Setting up BRI
Dear friend.
I have some problem when setting up BRI Interface (2B+D) in Vietnam.
This is my configuration:
Configuration:
interface BRI0/1/0
no ip address
no ip route-cache
isdn switch-type basic-net3
isdn twait-disable
isdn tei-negotiation preserve
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
end
Show ISDN Status:
ISDN BRI0/1/0 interface
        dsl 4, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 4 CCBs = 0
    The Free Channel Mask:  0x80000003
Debug ISDN Q921:
debug isdn q921
debug isdn q921 is              ON.
Jan 31 04:38:23.695: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
Jan 31 04:38:23.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan 31 04:38:24.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan 31 04:38:25.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Jan 31 04:38:26.291: ISDN BR0/1/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jan 31 04:38:26.291: ISDN BR0/1/0 Q921: User TX -> IDCKRP ri=18285 ai=0
Jan 31 04:38:26.695: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=0
Debug ISDN Q931:
Jan 31 04:47:39.707: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan 31 04:47:45.707: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan 31 04:47:51.707: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Debug ISDN error interface BRI 0/1/0
Jan 31 04:52:26.607: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
        L2: sapi 63 tei 127 ces 0 ev 0x3
Jan 31 04:52:26.611: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
        L2: sapi 63 tei 127 ces 0 ev 0x650
Jan 31 04:52:27.631: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Jan 31 04:52:27.707: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Jan 31 04:52:33.707: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Jan 31 04:52:33.895: ISDN BR0/1/0 SERROR: service_queue_from_physical_layer: got ISDN_PH_ACT_IND on an active interface?
Please help me to solve this problem.
I can't make call to PSTN.
Thanks all my friends.
VinhPLT
Are you trying to call 427 from Cisco to PBX ?
If so that is not the right configuration.
23 Replies 23
ronpatel
Level 8
Level 8
The status of ISDN is not correct. it should be
MULTIPLE_FRAME_ESTABLISHED and not AWAITING_ESTABLISHMENT.
Check with your service provider and see what is the issue with D channel.
Ronak Patel
Rate Helpful post.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Dear Ronak Patel.
Thanks for your help?
So which command should be chaged? switch-type of ISDN?
VinhPLT
I believe the switch type is correct. The  problem is with serivce provider. Please check with service provider.
Also send us the full router configuration.
regards
Ronak Patel
Rate Helpful posts.
Hi.
I send full router configuration.
how run
Building configuration...
Current configuration : 8254 bytes
! Last configuration change at 05:35:46 UTC Thu Jan 31 2013 by cisco
version 15.1
hostname FCV-VG
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2109617910
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2109617910
revocation-check none
rsakeypair TP-self-signed-2109617910
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
voice class h323 1
  h225 timeout tcp establish 1
license udi pid CISCO2911/K9 sn FGL1650115F
hw-module pvdm 0/0
--More--                           !
username cisco privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
controller E1 0/0/1
pri-group timeslots 1-2,16
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.28.90.60 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.232.72.39 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.232.72.39
interface Serial0/0/0:15
no ip address
--More--                            ip flow ingress
ip flow egress
encapsulation hdlc
isdn overlap-receiving
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
interface Serial0/0/1:15
no ip address
ip flow ingress
ip flow egress
encapsulation hdlc
isdn send-alerting
no cdp enable
interface BRI0/1/0
no ip address
no ip route-cache
shutdown
isdn twait-disable
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn switch-type basic-qsig
isdn skipsend-idverify
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.232.72.254
access-list 23 permit any
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
compand-type a-law
connection plar 713
voice-port 0/1/1
voice-port 0/0/1:15
mgcp profile default
dial-peer voice 700 voip
description *****Dial-peer to CRM*****
destination-pattern 7..
session target ipv4:10.232.72.31
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1 pots
destination-pattern 01.........
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
destination-pattern 09........
--More--                            progress_ind setup enable 3
direct-inward-dial
port 0/1/0
dial-peer voice 3 pots
destination-pattern [2-7].......
direct-inward-dial
port 0/0/0:15
dial-peer voice 4 pots
destination-pattern 0[2-7]........
direct-inward-dial
port 0/0/0:15
dial-peer voice 5 pots
destination-pattern 0[2-7].........
direct-inward-dial
port 0/0/0:15
dial-peer voice 300 pots
destination-pattern 3..
direct-inward-dial
port 0/0/0:15
dial-peer voice 600 pots
destination-pattern 6..
direct-inward-dial
port 0/0/1:15
forward-digits all
--More--                           !
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Thanks for your support!
VinhPLT
HI
Why is your BRI0/1/0 interface is shutdown.  Do following
1) Un Shut the interface.
Try and remove below lin kcommand form the BRI0/1/0
2)  no isdn point-to-point-setup
3) isdn static-tei 0
Do clear counters and send out ut of router# show interfaces bri0/1/0 after doing one ISDN test call command.
regards
Ronak Patel
Rate helpful posts.
Hi.
Interface was shutdown when I change switch-type. I forgot to up it
I send you show int bri 0/1/0 output after doing your command.
FCV-VG#show int bri 0/1/0
BRI0/1/0 is up, line protocol is up (spoofing)
  Hardware is Voice NT or TE BRI
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation VOICE, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:08, output never, output hang never
  Last clearing of "show interface" counters 00:01:18
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     14 packets input, 112 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     78 packets output, 364 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Hi.
For more information, I notice that BRI channel from PSTN have two port RJ-45 output through NT1.
When I connect a digital phone directly into NT1 output port, then the phone has signal (tone & display LCD up).
So can I use that port to connect to BRI interface? Is it different type between line use to connect phone and line to connect to BRI interface. This port is using to connect to SMTD3 card on Siemens HiPath 3800 and now I want to move it to Cisco 2921.
Best Regards.
VinhPLT
what cable you are using to connect your BRI port with NT box.
Ronak Patel
Rate helpful posts.
Hi.
I use pin 3-6 to transmit and pin 4-5 to receive.
VinhPLT
paolo bevilacqua
try
interface BRI0/1/0
no isdn static-tei
Dear Paolo.
When I used command no isdn static-tei, Layer 2 status is Inactive.
VinhPLT
Then static tei 0 is fine, now you try incoming and outgoing calls.
Note, unless you';re are familiar with CME already, the best approach is that you give the task to a reputable consultant, to avoid much loss of time and frustration.
Dear Paolo.
I have configure at least 3 CME with FXO, E&M and E1 Interface. And this is used as a H.323 VG, not CME.
And this is the 1st time I try to use BRI Interface for 2B+D.
I connect it to PSTN through NT1.
But something maybe wrong. When I connect both of output RJ (one to Cisco and one to Siemens), you can see the result abow. When we unplugged Siemens port to NT1, BRI Interface was down. I don't know what happen with it.
Regards.
VinhPLT
With point-to-point BRI circuits (static-tei 0), you cannot have multiple devices connected to the NT1.
So you can only have the Cisco, or the PBX connected at one time. You can power off the NT1 to have it reset and recognize the new device connected.
