ā02-08-2011 07:22 AM - edited ā03-16-2019 03:19 AM
Hi All,
IĀ“m running call manager 7.1 and when try to make calls to pstn calls are routed trought a voice gateway using a H.323 trunk.
When calls go out to pstn I would like to set up the calling number to my public pilot number ? I know is usual we do it at voice gateway with translation rules, but I would like to configure it on call manager instead. Where on call manager can I configure it ?
AB
Solved! Go to Solution.
ā02-08-2011 08:09 AM
Yes.
Caller ID DN
Enter the pattern that you want to use for calling line ID, from 0 to 24 digits.
For example, in North America
You can also enter the international escape character +.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
ā02-08-2011 07:25 AM
If you want all calls using that GW to have the main number, the best places are either at a route list or GW level.
java
ā02-08-2011 07:47 AM
Hi Java,
which filed do I supost to setup it at gateway configuration.
Acctualy I did set up my public pilot number at gateway conf >> call routing information - outbound calls >> Caller ID DN field
Is it right ?
AB
Yes.
Caller ID DN
java
ā02-08-2011 08:11 AM
Thanks Java that help me a lot
regards
AB
