Setting up DHCP and options for voice vlan
Colin Higgins
Level 2
Level 2
It has been a while since I configured this, and I can't seem to rememebr the exact way ...
I have 2 VLANS, voice and data. I have a DHCP range set up on the Catalyst 3750 switch for the data vlan, but I am not sure how to go about doing the same thing for the voice vlan, and how the phones will know which pool to pull from. Here is a hypothetical setup
ip dhcp pool Employees
network 192.168.120.0 255.255.255.0
ip dhcp excluded-address 192.168.120.1 192.168.120.20
domain-name mydomain.com
dns-server <servers>
lease 7
interface GigabitEthernet1/0/10
switchport access vlan 10
switchport mode access
switchport voice vlan 11
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
no mdix auto
spanning-tree portfast
How should I go about congiuring the pool for the phones? Which options do I use in the pool (150?)
thanks
Ayodeji Okanlawon
Your switch config looks okay..You have defined VLAN 11 as the voice VLAN..hence the phones will use CDP to discover they are in VLAN 11..
To create phones DHCP pool, you just need to configure your ip dhcp pool, and the configure option 150 ip with the tftp server ip...You shoudl consider how you will route between the VLANS..and you may need ip helper-address command if the dhcp server is on a different VLAN from the phones
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
If the DHCP server is the switch itself, do I need helper addresses?
Yes, depending on what VLAN the dhcp server is in..If its on the data VLAN then you should configure ip helper command on the voice vlan point to the ip address of the dhcp server
