settings and directories in ip phone 7931
how can i enter to settings and directories in the cisco ip phone 7931
thanks
Rob Huffman
Hi Moustapha,
Settings
1. Press line button 24 to access the Applications Menu key (default). If you are not sure of which button is configured as the Applications Menu key, use the Navigation button to display all button configurations.
2. Use the Navigation pad to choose Settings, or press keypad digit 3.
Directory
Press line button 22 if it is configured as Directories (default).
Press the Applications line button 24 and either navigate to Directories or press keypad digit 2.
Search for the requested name.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/ip_phones/7931/4.0/english/user/guide/ugKSsccp.html#wp38455
Hope this helps!
Rob
Rob Huffman
Hi Moustapha,
Settings
Directory
Hope this helps!
Rob
