Shared Line phones do not receive external calls simultaneously
APC-Shaban
I have 3 Phones 8865 on one shard line, the phones do not receive external calls simultaneously (when the external caller dial the land line then dial the shared extension) , one of them ringing only (Randomly).
Can you help in this ?
6 Replies 6
Can you make sure that the phone use extension in same partition.
8000 in partition A and 8000 in partition B are different number.
Response Signature
Thanks for your quick reply, I am using CME, please find the below configuration:
voice register dn 1
number 400
call-forward b2bua noan 404 timeout 10
name XXXX
shared-line max-calls 16
label XXXX
voice register pool 1
busy-trigger-per-button 2
id mac 3X41.XXXX.982B
type 8865
number 1 dn 1
cor incoming cssintl default
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 2
id mac 3X41.XXXX.B7AE
type 8865
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 3
id mac 3C41.XXXX.8643
type 8865
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
Check your  configurations for the below.
When the no supplementary-service sip handle-replaces command is configured, SIP shared-line is not supported on CME.
Response Signature
No it is not configured.
The phones do not receive external calls simultaneously (when the external caller dial the land line then dial the shared extension), does it work with internal calls ?
Can you share the CME configurations.
Response Signature
Yes it is working for internal calls,,,
Please find below the configuration:
version 16.8
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
no ip domain lookup
subscriber templating
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 500 min 60
voice class codec 10
codec preference 1 g711ulaw
voice class custom-cptone AR-custom
dualtone disconnect
frequency 399
cadence 500 500
voice register global
mode cme
source-address 10.10.11.10 port 5060
timeouts interdigit 2
max-dn 200
max-pool 100
load 7821 sip78xx.12-8-1-0001-455
load 8841 sip88xx.12-8-1-0001-455
load 8865 sip8845_65.12-8-1-0001-455
timezone 31
call-forward system redirecting-expanded
tftp-path flash:
create profile sync 1100410054503047
auto-register
voice register dn 1
number 400
name XXX
label XXX
id mac 3C41.0E34.982B
type 8865
number 1 dn 1
cor incoming cssosamah default
dtmf-relay rtp-nte
codec g711ulaw
id mac 3C41.0E34.B7AE
type 8865
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
id mac 3C41.0E34.8643
type 8865
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
application
service autoatt flash:its-CISCO.2.0.3.0.tcl
paramspace english language en
param operator 404
paramspace english index 1
paramspace english location flash:
paramspace english prefix en
param en 0
voice-card 0/2
no watchdog
voice-card 0/3
no watchdog
voice-card 0/4
no watchdog
voice-card 1/0
no watchdog
redundancy
mode none
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
ip address 10.10.11.10 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface ucse0/1/0
no ip address
shutdown
no negotiation auto
switchport mode trunk
interface ucse0/1/1
no ip address
shutdown
no negotiation auto
interface Service-Engine0/2/0
interface Service-Engine0/3/0
interface Service-Engine0/4/0
interface Service-Engine1/0/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip default-gateway 10.10.11.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0/0/1
ip route 0.0.0.0 0.0.0.0 10.10.11.1
tftp-server flash:/bootflash/isr4300-universalk9.16.08.01.SPA.bin
tftp-server flash:isr4300-universalk9.16.08.01.SPA.bin
tftp-server flash:Desktops/800x480x24/List.xml
tftp-server flash:Desktops/800x480x24/spftmb1.png
tftp-server flash:Desktops/800x480x24/spfwp1.png
tftp-server flash:boot1288xx.BE-01-007.sbn
tftp-server flash:fbi88xx.BE-01-012.sbn
tftp-server flash:kern288xx.12-8-1-0001-455.sbn
tftp-server flash:kern388xx.12-8-1-0001-455.sbn
tftp-server flash:kern88xx.12-8-1-0001-455.sbn
tftp-server flash:m0patch288xx.BE-01-001.sbn
tftp-server flash:preloader88xx.BE-01-002.sbn
tftp-server flash:rootfs288xx.12-8-1-0001-455.sbn
tftp-server flash:rootfs388xx.12-8-1-0001-455.sbn
tftp-server flash:rootfs88xx.12-8-1-0001-455.sbn
tftp-server flash:sb2288xx.BE-01-013.sbn
tftp-server flash:sb2388xx.BE-01-027.sbn
tftp-server flash:sb288xx.BE-01-026.sbn
tftp-server flash:sip88xx.12-8-1-0001-455.loads
tftp-server flash:ssb288xx.BE-01-007.sbn
tftp-server flash:vc488xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/kern2.78xx.12-8-1-0001-455.sbn alias kern2.78xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/kern78xx.12-8-1-0001-455.sbn alias kern78xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/rootfs2.78xx.12-8-1-0001-455.sbn alias rootfs2.78xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/rootfs78xx.12-8-1-0001-455.sbn alias rootfs78xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/sboot2.78xx.12-8-1-0001-455.sbn alias sboot2.78xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/sboot78xx.12-8-1-0001-455.sbn alias sboot78xx.12-8-1-0001-455.sbn
tftp-server flash:cmterm-78xx.12-8-1-0001-455/sip78xx.12-8-1-0001-455.loads alias sip78xx.12-8-1-0001-455.loads
tftp-server flash:cmterm-8845_65.12-8-1-0001-455/fbi8845_65.BEV-01-006.sbn.sbn alias fbi8845_65.BEV-01-006.sbn
tftp-server flash:cmterm-8845_65.12-8-1-0001-455/kern8845_65.12-8-1-0001-455.sbn alias kern8845_65.12-8-1-0001-455.sbn
tftp-server flash:cmterm-8845_65.12-8-1-0001-455/rootfs8845_65.12-8-1-0001-455.sbn alias rootfs8845_65.12-8-1-0001-455.sbn
tftp-server flash:cmterm-8845_65.12-8-1-0001-455/sb28845_65.BEV-01-015.sbn alias sb28845_65.BEV-01-015.sbn.sbn
tftp-server flash:cmterm-8845_65.12-8-1-0001-455/sip8845_65.12-8-1-0001-455.loads alias sip8845_65.12-8-1-0001-455.loads
tftp-server flash:cmterm-8845_65.12-8-1-0001-455/vc48845_65.12-8-1-0001-455.sbn alias vc48845_65.12-8-1-0001-455.sbn
control-plane
voice-port 0/2/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone AR-custom
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 1000
connection plar opx 400
caller-id enable
voice-port 0/2/1
shutdown
caller-id enable
voice-port 0/2/2
shutdown
caller-id enable
voice-port 0/2/3
shutdown
caller-id enable
voice-port 0/3/0
caller-id enable
voice-port 0/3/1
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
caller-id enable
voice-port 1/0/0
caller-id enable
voice-port 1/0/1
caller-id enable
voice-port 1/0/2
caller-id enable
voice-port 1/0/3
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
video
max-ephones 110
max-dn 400
ip source-address 10.10.11.10 port 2000
timeouts ringing 25
system message APC-SPF
url directories http://10.10.11.10/localdirectory
url services http://10.10.11.10/voiceview/common/login.do
url authentication http://10.10.11.10/voiceview/authentication/authenticate.do
time-zone 31
date-format dd-mm-yy
max-conferences 8 gain -6
call-park system application
moh enable-g711 "en_bacd_music_on_hold.au"
web admin system name Cisco password Cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 1..
transfer-pattern 2..
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
dial-peer cor custom
name ptinternal
name ptlocal
name ptmobile
name ptintl
name ptosamah
dial-peer cor list cssosamah
member ptosamah
dial-peer cor list cssinternal
dial-peer cor list csslocal
member ptlocal
dial-peer cor list cssmobile
member ptinternal
member ptlocal
member ptmobile
dial-peer cor list cssintl
member ptinternal
member ptlocal
member ptmobile
member ptintl
dial-peer voice 1 pots
corlist outgoing cssosamah
preference 1
destination-pattern 9T
port 0/2/0
dial-peer voice 10 pots
corlist outgoing csslocal
service autoatt
destination-pattern 9011.......
port 0/2/1
forward-digits 10
dial-peer voice 11 pots
service autoatt
port 0/2/2
forward-digits 10
dial-peer voice 12 pots
service autoatt
port 0/2/3
forward-digits 10
dial-peer voice 13 pots
service autoatt
port 0/3/0
forward-digits 10
dial-peer voice 14 pots
service autoatt
port 0/3/1
forward-digits 10
dial-peer voice 15 pots
service autoatt
port 0/3/2
forward-digits 10
dial-peer voice 16 pots
service autoatt
port 0/3/3
forward-digits 10
dial-peer voice 17 pots
service autoatt
port 1/0/0
forward-digits 10
dial-peer voice 18 pots
service autoatt
port 1/0/1
forward-digits 10
dial-peer voice 19 pots
service autoatt
port 1/0/2
forward-digits 10
dial-peer voice 20 pots
service autoatt
port 1/0/3
forward-digits 10
dial-peer voice 21 pots
description TollFree
service autoatt
destination-pattern 9800.......
port 0/2/1
forward-digits 10
dial-peer voice 22 pots
service autoatt
port 0/2/2
forward-digits 10
dial-peer voice 23 pots
service autoatt
port 0/2/3
forward-digits 10
dial-peer voice 24 pots
service autoatt
port 0/3/0
forward-digits 10
dial-peer voice 25 pots
service autoatt
port 0/3/1
forward-digits 10
dial-peer voice 26 pots
service autoatt
port 0/3/2
forward-digits 10
dial-peer voice 27 pots
service autoatt
port 0/3/3
forward-digits 10
dial-peer voice 28 pots
service autoatt
port 1/0/0
forward-digits 10
dial-peer voice 29 pots
service autoatt
port 1/0/1
forward-digits 10
dial-peer voice 30 pots
service autoatt
port 1/0/2
forward-digits 10
dial-peer voice 31 pots
service autoatt
port 1/0/3
forward-digits 10
dial-peer voice 32 pots
service autoatt
destination-pattern 992.......
port 0/2/1
forward-digits 9
dial-peer voice 33 pots
service autoatt
port 0/2/2
forward-digits 9
dial-peer voice 34 pots
service autoatt
port 0/2/3
forward-digits 9
dial-peer voice 35 pots
service autoatt
port 0/3/0
forward-digits 9
dial-peer voice 36 pots
service autoatt
port 0/3/1
forward-digits 9
dial-peer voice 37 pots
service autoatt
port 0/3/2
forward-digits 9
dial-peer voice 38 pots
service autoatt
port 0/3/3
forward-digits 9
dial-peer voice 39 pots
service autoatt
port 1/0/0
forward-digits 9
dial-peer voice 40 pots
service autoatt
port 1/0/1
forward-digits 9
dial-peer voice 41 pots
service autoatt
port 1/0/2
forward-digits 9
dial-peer voice 42 pots
service autoatt
port 1/0/3
forward-digits 9
dial-peer voice 43 pots
service autoatt
destination-pattern 99..
port 0/2/1
forward-digits 3
dial-peer voice 44 pots
service autoatt
port 0/2/2
forward-digits 3
dial-peer voice 45 pots
service autoatt
port 0/2/3
forward-digits 3
dial-peer voice 46 pots
service autoatt
port 0/3/0
forward-digits 3
dial-peer voice 47 pots
service autoatt
port 0/3/1
forward-digits 3
dial-peer voice 48 pots
service autoatt
port 0/3/2
forward-digits 3
dial-peer voice 49 pots
service autoatt
port 0/3/3
forward-digits 3
dial-peer voice 50 pots
service autoatt
port 1/0/0
forward-digits 3
dial-peer voice 51 pots
service autoatt
port 1/0/1
forward-digits 3
dial-peer voice 52 pots
service autoatt
port 1/0/2
forward-digits 3
dial-peer voice 53 pots
service autoatt
port 1/0/3
forward-digits 3
dial-peer voice 54 pots
corlist outgoing cssmobile
service autoatt
destination-pattern 905........
port 0/2/1
forward-digits 10
dial-peer voice 55 pots
service autoatt
port 0/2/2
forward-digits 10
dial-peer voice 56 pots
service autoatt
port 0/2/3
forward-digits 10
dial-peer voice 57 pots
service autoatt
port 0/3/0
forward-digits 10
dial-peer voice 58 pots
service autoatt
port 0/3/1
forward-digits 10
dial-peer voice 59 pots
service autoatt
port 0/3/2
forward-digits 10
dial-peer voice 60 pots
service autoatt
port 0/3/3
forward-digits 10
dial-peer voice 61 pots
service autoatt
port 1/0/0
forward-digits 10
dial-peer voice 62 pots
service autoatt
port 1/0/1
forward-digits 10
dial-peer voice 63 pots
service autoatt
port 1/0/2
forward-digits 10
dial-peer voice 64 pots
service autoatt
port 1/0/3
forward-digits 10
dial-peer voice 65 pots
corlist outgoing cssintl
service autoatt
port 0/2/1
dial-peer voice 66 pots
service autoatt
port 0/2/2
dial-peer voice 67 pots
service autoatt
port 0/2/3
dial-peer voice 68 pots
service autoatt
port 0/3/0
dial-peer voice 69 pots
service autoatt
port 0/3/1
dial-peer voice 70 pots
service autoatt
port 0/3/2
dial-peer voice 71 pots
service autoatt
port 0/3/3
dial-peer voice 72 pots
service autoatt
port 1/0/0
dial-peer voice 73 pots
service autoatt
port 1/0/1
dial-peer voice 74 pots
service autoatt
port 1/0/2
dial-peer voice 75 pots
service autoatt
port 1/0/3
num-exp 0 404
gateway
timer receive-rtp 1200
sip-ua
ephone-type 7821
device-id 7821
device-name cisco_cp-7821
device-type SIP
num-buttons 1
max-presentation 1
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
SPFRU01#exit
