04-29-2014 12:34 AM - edited 03-16-2019 10:36 PM
Hi all,
i have a C2921 with CME9.5 and some CP-6921 phones. My problem is, that on internal calls the phone only shows the directory number (1010) instead of the configured line name.
All phones are configured as SIP devices.
My config is attached below:
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 timeout t302 3
modem passthrough nse codec g711alaw redundancy maximum-sessions 15
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 3600 min 1800
voice register global
mode cme
source-address 192.168.11.1 port 5060
timeouts interdigit 3
max-dn 400
max-pool 110
load 9971 sip9971.9-3-2SR1-1
load 8961 sip8961.9-3-2SR1-1
load ATA-187 ATA187.9-2-3-1
load 6921 SIP69xx.9-4-1-3
authenticate register
authenticate realm all
timezone 23
time-format 24
date-format D/M/Y
mwi stutter
mwi reg-e164
voicemail 88000
url directory http://192.168.11.1/localdirectory
url authentication http://192.168.11.1/CCMCIP/authenticate.asp User Password
tftp-path flash:
file text
create profile sync 0292646025374671
network-locale DE
user-locale DE
camera
video
voice register dn 2
number 1010
call-forward b2bua busy 1000
call-forward b2bua noan 1000 timeout 22
call-forward b2bua unregistered 1038
allow watch
pickup-group 7
name Caller Name
label C.Name
telephony-service
srst mode auto-provision none
srst ephone description CCME-SRST MODE: : Jan 14 2013 12:37:38
authentication credential User Password
authentication credential evs tzgevs
em keep-history
pin 12345
max-ephones 100
max-dn 400
ip source-address 192.168.11.1 port 2000
service phone webAccess 0
service directed-pickup gpickup
system message Plasmatreat GmbH
url services http://192.168.11.3/voiceview/common/login.do
cnf-file location flash:
user-locale DE
network-locale DE
time-zone 26
time-format 24
date-format dd-mm-yy
voicemail 88000
max-conferences 8 gain -6
call-park system application
call-forward system redirecting-expanded
hunt-group logout HLog
moh "flash:music-on-hold.au"
web admin system name evs password tzgevs
dn-webedit
transfer-system full-consult
Does someone recognize the configuration issue?
04-29-2014 02:37 AM
Just a stupid question after the initial configs have you done no create profile and create profile again under voice register global?
I have even less config than you and my iphone on sip on the cme shows the calling name when dialing internal to another device.
04-29-2014 02:40 AM
Thank you for your quick reply.
Yes, i deleted and created the profiles, but nothing happened. I can't figure it out
04-29-2014 07:25 AM
The phone should be sending the calling name in the SIP Invite. If that's not happening, it's an issue with the phone not getting the correct info in the config files.
Try grabbing a "debug ccsip messages" for a test call.
