11-25-2019 05:03 AM
Dear Community,
I have a cisco CME with E1 sip connection for external calls. After every 8 hrs the line goes silent and when i restart the pabx the connection is restored!
What causes the sip connection to go silent and how can it be resolved? Please find edited running configs attached.
! card type command needed for slot/vwic-slot 0/3
logging buffered 10000000
no logging console
no logging monitor
aaa new-model
aaa session-id common
clock timezone GMT 3 0
clock calendar-valid
voice-card 0
dspfarm
--More-- !
voice service voip
ip address trusted list
ipv4 192.168.1.0 255.255.255.0
ipv4 192.168.15.0 255.255.255.0
ipv4 10.0.0.0 255.0.0.0
ipv4 192.168.100.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.3
no supplementary-service h450.7
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no fax-relay sg3-to-g3
h323
h225 timeout ntf 50
--More-- h225 display-ie ccm-compatible
call start slow
sip
registrar server expires max 1200 min 300
no update-callerid
no silent-discard untrusted
g729 annexb-all
sip-profiles 300
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
codec preference 5 ilbc
voice class sip-profiles 300
request INVITE sip-header From modify "(<.*:)(.*@)" "<sip:+*************"
voice class dualtone-detect-params 2
cadence-variation 20
--More-- !
voice class custom-cptone Disconnect_KE
dualtone disconnect
frequency 450
cadence 350 350
voice iec syslog
voice register global
mode cme
source-address 192.168.x5.x port 5060
timeouts interdigit 2
max-dn 200
max-pool 50
load 7942 SIP42.9-4-2SR1-1S
load 7962 SIP42.9-4-2SR1-1S
load 7821 sip78xx.10-3-1-12
timezone 31
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0992065064273416
video
--More-- !
voice register dialplan 1
type 7940-7960-others
voice translation-rule 1
rule 1 /***********************
voice translation-rule 2
rule 1 /************************************
voice translation-rule 3
rule 1 /***************************************
rule 2 /***************************************
--More-- voice translation-profile INCOMING_CALL
translate called 3
voice translation-profile OUTGOING_CALLS
translate calling 2
translate called 1
license udi pid CISCO2911/K9 sn FGL171411JU
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
redundancy
--More-- !
gw-accounting file
primary ftp FTP_server/ username admin password 7 130E1E1F021F0D3E3E76786260
acct-template callhistory-detail
maximum buffer-size 25
maximum retry-count 3
maximum fileclose-timer 300
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
--More-- ip address 192.168.1.x 255.255.255.0
interface GigabitEthernet0/0.15
description VOICE VLAN
encapsulation dot1Q 15
ip address 192.168.x5.x 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface ISM0/0
ip unnumbered GigabitEthernet0/0.15
service-module ip address 192.168.y5.y 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.x5.x
interface GigabitEthernet0/1
description ** WAN Interface**
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.899
description *************************
encapsulation dot1Q 899
ip address 1.2.9.4 255.255.255.252
ip nat outside
interface GigabitEthernet0/2
ip address 1.1.4.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface ISM0/1
no ip address
interface Vlan1
no ip address
interface Vlan15
no ip address
interface Dialer1
--More-- description ***WAN
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname YYYYYYYYYYYYY
ppp chap password 7 XXXXXXXXXXXXXXXXXXX
ppp pap sent-username RRRRRRRRR password 7 BBBBBBBBBBBBBBBBBBBBBBBB
no cdp tlv app
ip forward-protocol nd
ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip ftp username admin
ip nat inside source list 102 interface GigabitEthernet0/1.8 overload
ip nat inside source static 192.168.x5.y ag.agg.gg.gg.
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/2
ip route ****************************
ip route ************************* ISM0/0
ip route *****************************************
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
--More-- mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 700 voip
description UUUUUUUUUUUU OUTGOING via SIP
translation-profile outgoing OUTGOING_CALLS
destination-pattern 9T
redirect ip2ip
session protocol sipv2
session target ipv4:10.66.56.138
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs5 signaling
dial-peer voice 701 voip
description UUUUUUUUUUUUUU INBOUND CALLS
translation-profile incoming INCOMING_CALL
session target sip-server
incoming called-number .%
voice-class codec 1
--More-- voice-class sip bind control source-interface GigabitEthernet0/0.15
dtmf-relay rtp-nte
no vad
dial-peer voice 300 voip
destination-pattern 3..
session target ipv4:192.168.1.25
voice-class codec 1
gatekeeper
shutdown
telephony-service
max-ephones 50
max-dn 50
ip source-address 192.168.y5.x port 2000
service directed-pickup gpickup
--More-- timeouts transfer-recall 15
url services 192.168.15.254
url authentication 192.168.y5.x
max-conferences 8 gain -6
call-park system application
moh enable-g711 "flash:music-on-hold.au"
multicast moh 239.23.4.10 port 2000
web admin system name a password
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Nov 18 2019 17:23:29
Isaac.
11-30-2019 07:08 AM
Have you notified your Telephony Provider concering this performance, in order to enable some kind of debugging on the line to identify if there is anything on this end?
George
11-30-2019 08:29 AM
Dear George,
thanks for the reply, i havent but i will have to. On my end is everything looking good?
Isaac
11-30-2019 10:12 AM
Hello Isaac,
I haven't seen something wrong on your running-config. If possible, please post your logs from "debug ccsip messages" when you notice the issue.
Instead of reloading the CME have you tried to shutdown/no shutdown the interface that you have your E1 connected?
I am sure that your Provider would be able to assist you accordingly, based on the messages he will receive during the issue.
George
11-30-2019 10:02 PM
Dear George,
I normally shut/no shut the sip interface to service provider and the line comes up, I will post the debug as proposed. Thanks once again!
Isaac.
