CME to ITSP SIP
Precious
ciscotac.pngHi Cisco Family,
I have a CME with 2 registered 7911 phones,
Everything is working as its supposed to but we are no able to make outgoing calls. incoming calls are working fine.
when I do debug ccsip messages command, I keep getting :
sip/2.0 403 forbidden authentication failure even though my SIP trunk is registered.
Attached are my CUBE configuration
marcfuhrmann
I am missing the bind command in your configuration:
You can use something like this:
bind control source-interface GigabitEthernet0/0.300
bind media source-interface GigabitEthernet0/0.300
With a newer image you can use "tenant" for multible sip provider and make the bind command under each tenant.
I use this image:
c2900-universalk9-mz.SPA.156-3.M7.bin
Hope this helps.
Marc
Hi, thanks for the reply, I am binding ITSP voip dial-peer to G0/2
j.huizinga
Level 6
Level 6
The your caller-ID, providers check on caller-id, mostly providers check caller-ID for security and billing
