Simple accounting on C2801
mhostbaek
Hello ,
I have a 2801 running c2801-advipservicesk9-mz.123-14.T5.bin - I have a few phones connected to it; doing remote breakout on simple ISDN lines.
Is there a way (with this software) to see how many outgoing / incoming calls I have had per number , and the total minutes in-call ?
Many thanks,
Mike
Stoyan Stoitsev
Level 8
Level 8
If you're having ip phones with ccm use the cdr data.
What you can check in the router is
#show call history voice
and you can set this with
(config)#call-history-mib max-size/retain-timer
I've got simple 7940s... I guess I need special software to view the CDR data..
