I have a 7960 cisco ip phone, how do i forward a call that comes to my extension to my cell phone which is a (805)***-****. Thanks
We have a number of laptops with IP Communicator 2.0.0 installed on them. IP Communicator works perfectly when the laptops are connected to local network. However when they connect via SSL VPN, the "Services Button" doesn't work properly. When the...
Hello therehow is CCM 4.2(.3) resolving Caller Names or how do i make this feature to work?If someone is ringing in, is there any possibility to check the (global) Directory for the number and displaying the Callers Name then?Thanks in advance for an...
Hi all,I have a call manager 4.0 running and a voice gateway configured with DID.When i call from my GSM phone to the IP phone the number doesn,t appear on the IP Phone.How can i make it appearNote: I m using FXO port not E1ThanksEric
Is there any way within CME 4.0 to call-foward noan and call-forward busy to different numbers based on the incoming called number. I have set up the ephone-dn such that the primary is a 4-digit extension and the secondary is an alternate 10-digit E...
I have a 7912 that is displaying every missed or received call as the same number. It displays the correct number when the call is in progress, but then when reviewing missed/received calls it displays another number. Resetting the phone did not help...
Hi, I'm setting up a h323 trunk between Cisco 3725 (C3725-IPVOICE-M), Version 12.3(14)T7) and S8700 of Avaya.I'm attaching the configuration of the 3725 router.This trunk is not up, even in the same LAN. Is there any more commands to see what's going...
Hi,I have got a voice detection trouble with my 7912 cisco phone, is there a way to manage the voice detection or to disable it without cisco call manager (my cisco phones are all running with the sip protocol).Thnak you very much for your answer.Bes...
We try to use 7941 IP Phones with SIP firmware for a special application (without Call Manager but SIP Proxy). Does anyone know if VAD parameters can be changed on the phone (like on IOS Gateways with "music-treshold" and "voice vad-time")? Need to i...
Dear all,I am planning to implement cisco ip softphone in my network, I have 2811 router with version 12.4(4)XC4. So any one can guide me for the configuration.Jitesh
I want to configure voice vlan and data vlan in c3560 ... and dhcp server of each vlan on windows server...do we need a switch with layer 3 functionality to do routing between different vlans ?? if so does cat 3560 has layer 3can someone please help ...
Hi all,I have configured a 3800 router and the call Manager 4.0I have DID configured but i rather use connection plar opx for the direct line.when i call from outside (21202285) it gets alright to the extension (5200).I want only the user of extensio...
I was asked the other day about my Cisco VIOP phone system and was asked a question that I didn't know the answer to. How do 7960 phones know to be in the voice VLAN. Furthermore how do they know what VLAN to let the computer attached to it to be i...
Hi, I have installed a b-acd that works ok. But the only thing that I can not manage is the go off time or hook time of b-acd. I mean, when my company receives a call the first greeting time ("en_bacd_welcome.au")is heared after 4 ring tones. How can...
I want to show caller id or caller number in a mobile phone wich it is forwared from a 7940 phone in my company.Is it possible?. How can I do it?.Thanks.
| Subject | Author | Posted |
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 4 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
