01-07-2008 03:05 PM - edited 03-15-2019 08:05 AM
Suppose DN A and DN B be in the same partition; Can A call B even if A has no CSS assigned?
THX...
01-07-2008 04:55 PM
if no CSS assigned then I supposed that you have it as None, correct? if this is our case then you can only call DN's that are not assigned to any partition, in other words set to none. CSS None can only call to None Partition.
So from what I understand you have the DN A and DN B assigned to a partition other than None so in that case you can NOT call B if you have the None CSS.
01-07-2008 08:07 PM
I may be wrong, and I probably am, but I was thinking that if you didnt assign a CSS, it would be assigned to the "default", which had access to all CSS. Im not sure why I think this, and I probably need to rethink it, but for some reason, I thought this. Anyone else?
01-07-2008 08:16 PM
Ok, I cant find any documentation on this, so please disregard what I stated above.
01-07-2008 11:54 PM
Thx....i you understood well...i wil try in alb env.
01-07-2008 10:37 PM
Yes its possible provided you specify the CSS in the global mode and its none in the Line configuration mode.
Thanks.
